Originally Posted by dr_hsu
Can you tell where that buzzing is coming from? Is something vibrating due to that sub position? Try to nail down the source of the buzz. How about the left rear corner? If the main speakers are crossed over at 80 Hz, I still don't understand why you find the bass so different even after SMS EQ. That should have flattened the response, so other than differences in headroom, there should not have too big a difference.
I think the buzzing was coming from a bump around the 80Hz region. As requested, here are two placement options with their respective FR graph.
Rear Left Corner:
Middle Firing into Couch:
To my ears, the rear left corner sounds better, although a little boomier and a bit localized. Much more output tough and less "buzzing" upper bass. It really gives great punch too!
The middle placement is very tactile, but I have the impression that I feel more bass than I ear.
What do you think? What EQ should I use (cut or boost?)?
