Originally Posted by audiofreak38
bori if you have your speakers calibrated to 75 db then run the sub say at 77 db. That would be considered a bit hot. I run my auto set-up first then recheck w/my RS SPL meter. It does the job for me. I also recalibrate my sub to the Rives Test CDII so ensure that I am getting a close to a flat response as I can. Run the Audessey program and then recheck with your RS SPL meter. Afterwards, go back to the sub a set the level so that you are reading 77-78 db. Then adjust from there. Only you can decide if that works for you. If your sub sounds like it is drowning out your fronts then adjust the level down a notch by 1db until it sounds the way you want it to. Likewise, you may need to turn it up and run it even hotter but I doubt you will. Hope this helps.
I had the volume set to half way and the receiver to 0 during the U-571 depth charges and I heard some muffling during the depth charges. Was that normal or did I have the setting too high. I thought this sub can handle these scenes with ease. Please let me know what you think.
I'm basically going to shut down the HT until it comes back - that's a testimate to how darn good this sub is - I don't want to watch anything without it!
