Originally Posted by LDBetaGuy
Every subwoofer description and review I've read concentrates on how much low frequency sound the subwoofer can produce. I'm interested in finding out about the highest frequencies a subwoofer can comfortably produce. I'm specifically interested in the Hsu STF-1. I'll be mating it with some Polk TL3 speakers and will be setting my 5.1 receiver's crossover to 100 to 110. Will the STF-1 do a good job of producing those upper sounds around 100 Hz? In general, is there a big difference among subwoofers in how well they produce the higher frequencies?
All of our subs are flat up to at least 200 Hz, more than enough for a subwoofer. 100 - 120 Hz is not an issue for our subs. The only issue with a high crossover is the sub tend to be a lot more localizable. You need to place it up front between the two main speakers, or directly behind you.
