There are so many things to consider !! After weeks of research, I just can't do it anymore, and have to make a decision. Here are the models on my short list - I would appreciate any feedback :
Pioneer DVR640HS - everyone's favorite it seems, except for the Toshiba guys. Like all of these units except the Polaroid, I do think 160 GB will fill up, and that is the main problem. The firmware problem is fixable, even though sending it away for 8 weeks sucks, royally. The part about not being able to pull chapters out of one show and insert it into another compilation (whereas this is doable on the Toshiba) is a valid concern, although I am not sure how often I would need to do that, because I make my custom DVD's on my computer.
Thanks;
ls
- Polaroid 2001G (80 GB but hackable)
- Panasonic DMR-EH75VS (80 GB) or DMR-EH55-S (200 GB)
- Pioneer DVR640HS (160 GB)
- Toshiba RD-XS52 (160 GB) or RD-XS35 (160 GB) or XS32 (80 GB)
- Question - with the Polaroid, what does the drive file structure look like if you connect it up to a PC ?? Is it editable? Can you import a DVD or a TV show from the drive onto them main drive of your PC and send the files to friends or family?
- Question - I read NextToo's sequence of mods for about 2 hours - great work there. But then I see how he is recommending the Toshiba. I wonder why since he did so much work with the Panny? My guess is he uses the Panny for storage and the creation of a library, but that he uses the Toshiba for day-to-day operation. I only will use one unit - so have to decide whether I want storage, or usability.
- Question - how do the others do it ? That is a bit unclear to me. Preferably, just with this unit - they could dub on the fly, right to DVD. But I do not think they can, can they? It is much more time consuning since you need that oter step of recording to the HD first.
- Question - I read that Pioneer has "fixed the firmware" so I assume their new units coming out of the factory do not have this problem. Does anyone know how I could make sure that I find a unit that already has the firmware upgrade in it?
- Question - since the Toshiba has a 160 GB drive just like the Pio, and it does not have the limitation of not being able to move chapters from one show into another using the original recording, and it does not require a firmware upgrade . . . why buy the Pioneer ??
Thanks;
ls
