AVS › AVS Forum › Audio › Speakers › Please see my pics of apt. for speaker placement advice. Seriously, I need help.
post #1 of 12
Ok, I need some major help here. I just need your opinions on a 7.1 speaker placement in my apartment. It is one of those living rooms with a big open area. Now, if you look at the pic by my front door, you can see my black audio rack; it is 5 feet tall. Is this an ok height for the mains? center would have to be at 4 1/2 due to TV. Now, I the main thing I have to figure out is where to place my 4 surrounds. As you can see, I have no space behind my couches, and I really only have two walls to work with, However, I do have that column in my living room, which I could mount a speaker to. You can see the old crappy speakers I have. I am leaving them there for reference points for this purpose. I am guessing these new ones should be a bit higher than those. Please take time to look at this, if you have the time that is. I really appreciate it, and everything I have learned on here. thanks a lot!
post #2 of 12
My peeps, these speakers won't hang themselves. JK, I do still need some help with this. Anyone out there in AV land?
post #3 of 12
whelp, thats quite a pickle you have there. Having the mains at 5' isn't that bad, its good that you have them about the same height. It is hard to gather much from the pics you have provided, if you don't have places for 7 speakers, use 5. I would offer recommendations but I can't see just how your theater comes together from those pics, it looks like you have tiny surrounds, why not just stand mount them?
post #4 of 12
Those are the old surrounds. I will be using Velodyne CHT series bookshelf speakers. I imagine I will have to make small wall stands for them. If anyone looks at the pics, I was thinking about 1 on the column, 1 across from it, by my quad-painting, and two in the back somewhere? I guess these things are going up nonetheless, but I am sure there is a spot for all of them, somewhat.
post #5 of 12
You certainly like water & fish.
post #6 of 12
As army mentioned, it's almost impossible from those three pictures to figure out how the room is laid out. I don't really see anything in any of the pictures that would lead me to believe they're even of the same room, even if they are. You don't even mention the room dimensions.
A better move would be to take measurements and make a scale drawing of the space from overhead, being sure to mark doors, windows, open walls, etc. With an overhead drawing, it would be easier to figure out where certain things could go.
That, and liks someone else mentioned, 5.1 might be just fine given a) lack of space b) lack of mounting space, and c) it's an apartment.
I only have 5.1 in my house, in a 10x10 room. While it would be nice to have 7.1, I have no room for it, and I have few, if any, 7.1 sources. Unless you have the room for it, I don't think 7.1 is necessarily worth it in too many things in such a non-permanent, acoustically difficult environment such as that.
post #7 of 12
That room looks like what happens when you try to put 10 pounds of potatoes into a 5 pound sack!
post #8 of 12
the room is 12 x 15, not including open kitchen area, you know. Basic apartment.
post #9 of 12
Jared,
It looks like you need to make some room for your audio gear. First suggestion is drop the 7.1 idea. I'd go with 5.1.
Can you condense the tanks into one? It appears you have room for rear speakers. The front would be a challenge unless you can create space underneath your display for equipment storage. The photos do make it difficult to get an idea of your room.
Then there is the door. With a room that size, you will not need large speakers. Floor standers due to all the stuff you have in there would be a challenge. You might want to use small monitors at the corners and a small center channel.
My comment would be get rid of the big stuff if possible, design from there and forget the 7.1 idea. That's my .02.
WE all need help. You are not alone!!
Good luck....
post #10 of 12
Cool, thanks! I am not going to use floor speakers, they are going to be on top of the audio piers, and the center will be on top of the TV. Thanks for the help people, anybody else feel free to add to this. Really do.
post #11 of 12
I like the fish tanks, I have a 80 gal myself. Im wanting to buy a 180 gal here soon
post #12 of 12
I am going to be another 5.1 supporter here. You need room behind your listening position to really appreciate 7.1(the back two speakers in a 7.1 system should be mounted at least a few feet behind the listening position). I would mount the surrounds higher on the side walls and aim them each towards the center of the couch and slightly above the center listeners ear level. This worked out best for me and my 5.1 system. It is hard to get a feel for your room layout though but this seems the best layout from what i can gather from your photos.
  Back to Forum: Speakers
