Bfeils found this product called Clearshield by Clearstar. You can buy it here. It looks interesting from the info posted on the website. I know nothing more than that. The matte or satin may be a good coating for the Wilsonart laminates. It could also be used for roll-up or flexible screens. Two quarts should be around $50 and should be plenty to spray a screen. For a clear coat on a laminate, one quart plus a Wagner sprayer should set you back less than $100.
