Originally Posted by
meegari
yep got mine 17.99 normally 29.99 and my rope lights for 9.99big thanks to volley for sending me the file, thanks man!!! Now i edited the graphic i need to somewhere to print it, does kinkos do this?? I tried on transparent paper but the seam is way too obvious!
Wouldn't you need to print on white paper of some sort to get the diffuse glow?
And I have also edited the file that volley sent to me to make the marquee a little bigger and for more space to write some kind of message. Here it is, as of now, although I'm not sure the message will be the same as what we will actually go with. And I used Adobe Illustrator for the text, although I couldn't get the text to look the same as what Volley's looked like, but I ended up stumbling upon this look, and like it, so I am sticking with it, for now.
Dachavez--what kind of paper did they print it on for you? My thought is to use it in a bigger shadowbox--I would imagine Kinkos or other printers can print on to large size photo-type paper, anyone know if that is true?
Thanks to Volley for doing the initial work on this.
