I wasn't sure if I should put this in the DIY board or here, but I decided to put it here.
I'm waiting for a set of 4x Onix x-ls and 1x Onix x-cs to arrive (
), and as they're the not-as-new version, they don't have and weren't designed for speaker grills.
I would like to see if there's anything I can do something to protect them a little, and was wondering if there are any ways to secure grill cloth to them without using a drill? Would just wrapping grill cloth around the whole speaker a couple times work?
(If you look at my occupation in my profile, you'll see that aesthetics are not really an issue for me
and also, would partsexpress.com be a good place to get the cloth?
), and as they're the not-as-new version, they don't have and weren't designed for speaker grills.I would like to see if there's anything I can do something to protect them a little, and was wondering if there are any ways to secure grill cloth to them without using a drill? Would just wrapping grill cloth around the whole speaker a couple times work?
)and also, would partsexpress.com be a good place to get the cloth?
