AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Proper 7.1 Speaker setup - Help....
post #1 of 2
We just redid our basement and I upgraded from a 5.1 to a 7.1 system.
My question is whether my rear channels (not the 2 rear centers, but the 2 rear sides) are misplaced. The contractor installed them in-wall slightly IN FRONT of the seating area. I can shove the sofa forward to get even with the speakers but that creates some issues with TV viewing and room flow. The 2 center rears are well placed. It's not entirely his fault as we didn't really know at the time where the sofa would go. The rear L/R speakers are in the ceiling facing down because we couldn't utilize side walls.
I think the system sounds great but have read that those two rear channels should be 12-20 degrees behind the listening area. I can have them moved back but it'll mean an argument with the contractor (whom I need to maintain good relations with), a re-drywall to patch the existing holes and some touch-up paint. I'm willing to move them back if those-in-the-know think things are compromised as they currently are.
Thanks in advance.
post #2 of 2
Move 'em back behind the listening area. You don't have to argue with the contractor. Was it his/her fault?
If you didn't provide detailed instructions during the building process then expect to pay for the time it takes to correct it. And yes, it would be worth it.
