AVS › AVS Forum › A/V Control & Automation › Remote Control Area › remote code for Comcast HD box- HELP!
post #1 of 5
hello! I just picked up a Samsung 42 inch Plasma. I will eventually get a harmony once I am 100% sold that it will work with my stuff, but in the mean time....
I managed to get my DVD player to be controlled by the Sammy remote. I'd really really like to get my Comcast DCT3416 I to be recognized too, but the codes provided just don't work.
Do any of you have the code for this box, and know if I can access the on demand and guide stuff from the Samsung remote?
post #2 of 5
Depending on which remote you got with the cable box, and which TV and DVD model, it might be easier to use the DVR's remote to control the others. You only generally need to control the volume, aspect, and input on the TV, while there's a lot of keys needed for the DVR that the DVR's remote already has. It will also have the keys for DVD player. Is your DVR remote one of silver ones here? Also what is the model of the TV and the DVD player you want to control?
post #3 of 5
It is a 3 in 1. And I wanted to used the Samsung remote to control everything. I already figured out how to get the Comcast remote to control everything...I wanted to use the Samsung remote to control my cable.
post #4 of 5
Anyone have the correct code? 064 does not work.
post #5 of 5
Try 038 - my cable box is a Motorola, but the code for Oak boxes worked.
Good luck.
  Back to Forum: Remote Control Area
