AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › Connecting to Vizio LCD
post #1 of 2
So I jjust picked up a MacBook Pro a few days ago & was wondering as to what cables I need in order to hook it up to my 47inch Vizio...
I don't want to get a DVI to HDMI cable because I am using up all the HDMI inputs on the TV already.
I want to be able to use the TV's computer input which says that it is an RGB input... how do I get a DVI to RGB adapter? The coomputer already came with a DVI to VGA adapter which doesn't fit into the RGB port of the TV.
post #2 of 2
The DVI to VGA adapter that came with the Mac isn't meant to plug directly into the TV. You are supposed to plug the adapter into the Mac and then get a VGA cable to go between the Mac and the TV.
  Back to Forum: HTPC - Mac Chat
