AVS › AVS Forum › HDTV › Local HDTV Info and Reception › digital cable..?!
digital cable..?!
post #1 of 3
OK-- I wanna get digital cable with HDTV-- I'm in mound, minnesota, like that matters...
anyways whats the best way to get Digital cable with HDTV...is it DirectTV or something like Time Warner?? any thoughts?
post #2 of 3
The best way to get digital cable is from your cable company. The satellite companies like DirectTV and Dish don't supply digital cable. Perhaps you meant "what is the best way to get HDTV?". OTA is always typically the best quality if you can get it. Start here to find out how close you are to the transmitters:
http://www.antennaweb.org/aw/welcome.aspx
If you want more than just local HDTV, then you'll have to see what other folks think about cable in your area. (Look for your area in the AVS forum.) It could be better or worse than satellite. Also, you'll have to decide which channels you want. Typically satellite has more HD channels than cable.
post #3 of 3
Check the United States Thread Index at the top of the forum to find the thread for the Minneapolis DMA cable company that serves your area.
This thread is locked
