Originally Posted by
project_x
"A design flaw is when something is specified in the design requirements (usually by marketing or program management) fails to work as required."
I respectfully disagree, a design flaw is not a departure from the design requirements.
Thanks for being respectful. But I've seen too many cases of folks blaming something on designers when it was clearly a choice of management to do something a certain way. And this is clearly one of those cases.
project_x
Obviously it has been a concious decision of the television manufacturers, but it is most certainly a flaw in the design. We send a digital audio signal to the TV via "the one cable HDMI solution" , I think that one would have a reasonable expectation to have this digital audio signal come out of "digital out" on the set.
Well the User Manual and the Specifications for the set make it pretty clear that the HDMI audio input is for 2 channel PCM sound only.
project_x
What is the point of using an HDMI cable at all, if we need to pass around digital audio?
As the TV has stereo speakers, it can receive sound from the HDMI cable. The problem is that the set tells the sending device to only send 2 channel (so they don't have to decode 5.1 - thereby needing a 5.1 decode license)
project_x
I would have to review a copy of the Dolby licensing agreement, but suspect that one is allowed to pass an undecoded digital audio signal through a unit without any royalty fees, otherwise, there would be royalties on optical splitters, HDMI switchers, possibly HDMI cables,......
But, as I pointed out above, the TV needs to play (on it's speakers) the sound from the source. It can only do that if: 1) It tells the source to send only 2.0; or 2) It has a 5.1 decoder to separate out stereo for the speakers &
that is what the license is for. Sorry, I should have made that clearer before.
