AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Still Can't Decide
Still Can't Decide
post #1 of 13
I'm still having a hard time deciding which LCD to buy. I need it for DVDs, xbox 360 and cable television as well.
I need a 40" + size and don't really want to go over 2500..what do you guys recommend?
post #2 of 13
Olevia 742i
post #3 of 13
How close do you sit? And what is the lighting in your room like?
post #4 of 13
Jvc Lt-40FN97
post #5 of 13
8ft...and there is lighting, unfortunately.
post #6 of 13
The JVC had bad reviews on cnet..do you agree with those reviews?
post #7 of 13
You need to read the user's comments. I have not read the CNet review. I own the LF-40FH96 and love it!! I've owned it a year. As for reviews, CR identified it #1 (Mar 07) over Sony and plasmas, for displaying HD.
post #8 of 13
O, ok, i'll read up on it, and how would you compare the JVC to the Aquos..bestbuy has the 42" on sale for $1800
post #9 of 13
I have not viewed the Aquos so do not feel 'qualified' to give you an opinion on that set.
You might read this article before you buy any set: http://www.hometheatermag.com/hookmeup/1106hook/ I don't know if the Aquos is addressed but it should provide some clues as to what to look for......
If you are interested, here is another on the JVC
http://www.tvpredictions.com/jvc40120106.htm
post #10 of 13
Gonna check that link out right now..I also came across the Toshibs Regza..seems promising.
post #11 of 13
The LC-46D62U Aquos is considered the new Aquos, i just read reviews and it seems improved compared to the others.
http://hometheatermag.com/lcds/207sharplc46d62u/
post #12 of 13
Good luck with your search
post #13 of 13
Thank you, I have a problem with JVC, the past 2 tvs were JVC and they always had problems..
