AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › HDMI/DVI/Sharp PG-M20X (DVI 1.0)
post #1 of 2
4 year old Sharp PG M20X
(with DVI input; manual says it's DVI 1.0, not working with DVI 2.0)
Panasonic Upconvert DVD player with HDMI output
HDMI-HDMI cable
HDMI-female-to-DVI adapter
After I connected DVD player output to HDMI, and used HDMI-DVI adapter to connect to the projector, the project flickered quite a few times trying very hard to "adjust the picture quality". It never stablized and I couldn't get anything.
The SHARP manual said the projector supports only DVI 1.0... I wonder if this is the reason why? Anybody provides any input?
Thanks a lot!!!!!!!!
post #2 of 2
After some research, I believe it's because SHARP PG-M20X is not HDCP compatible, and thus no signal is passed from the HDMI/DVI cable. What options do I have then? These are the two that I can think of that are low budget.
1. Buy a HDCP-free DVD player with up-convert/HDMI?
2. Hack my Panasonic S52S player to make it HDCP-free?
Any suggestions?
