There are serious mechanical problems in doing film at higher frame rates. Intermittents have to yank the film down for each frame, and it becomes very hard on the film and equipment.
30FPS has been used as mentioned in early ToddAO. 48FPS and 60FPS have been used. Doug Trumball had a process called Showscan that was 70MM at 60FPS. Looked really great.
One of the problems with higher frame rates is then you have to downconvert. The first two movies shot in ToddAO (Oklahoma! and Around the World in 80 Days) were actually shot twice, once at 30FPS and once at 24 FPS. Beginning with the third ToddAO picture (South Pacific), the frame rate was changed to 24FPS just to avoid double shooting.
I personally believe that frame rate is the largest single issue today. We don't realize how much better things would look at higher rates because we normally don't see them. This is particularly true of today's fast/action fast/cutting films, that often really look more like a big jumble than anything realistic.
I would like to see all production at 4320P120. A rate of 120RPS is neat because 120 is evenly divisible by 24, 30, and 60, thus allowing us to downsample easily to all known formats.
PAL is still odd-man-out at 25FPS. Why that happened is a mystery to us all.
