AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › Does new JVC HD1/RS1 do vert stretch?
post #1 of 33
Does the new JVC unit do the necessary stretching for CIH?
post #2 of 33
No....
post #3 of 33
So the question that needs to be addressed by JVC, why don't we have the 2.35 stretch option? The processor is easily capable. What excuse is there? Tom?
post #4 of 33
From what I understand from the (downloaded) manual, the Zoom function will do the required vertical stretch needed for CIH, but it only works for SD input sources. I hope someone can confirm or refute this.
Zoom mode in widescreen projectors is a "hangover" from the days of LaserDisc and non-anamorphic enhanced widescreen DVD's where 4:3 formatted video (with widescreen content) is stretched horizontally (to fit a widescreen display) and vertically to eliminate or minimize the black bars and restore image geometry.
I too hope JVC can provide a "proper" CIH solution for the HD1/RS1 without the need for an external scaler.
Michael.
post #5 of 33
Yes it will be seen and checked on the 9th March.
Ben
post #6 of 33
Why? What is March 9?
Tom T, any update... please!! Stretch is the only thing holding me back.
post #7 of 33
Won't this still require the source to be anamorphically enhanced?
Mark
post #8 of 33
The DLA-HD1 has "Letterbox" Aspect Ratio that does the vertical stretch. Unfortunately, it works only on SD input signals, NOT HD! Whenever you input 1080i/p, the projector assumes the source must be 16:9 and won't allow vertical stretch with the "Letterbox" AR.
Maybe JVC will come up with a fix/upgrade.
post #9 of 33
Communication has been sent ot Japan and requested.
Ben
post #10 of 33
Ben,
This feature was requested months ago by JVC engineers in the USA. Have you gotten some sort of indication that the VS feature will be added or did you just send in a similar request?
post #11 of 33
Originally Posted by Jagercola View Post
Ben,
pardon my ignorance (not much anamorphic in UK) - assuming JVC offer firmware upgrade, will this then allow all horizontal pixels to be visually active (1080 not 810) then require a corretive lens
As such a lot of 1080 movie material is 2.35 shouldnt a quality 1080 PJ supplier offer alternative screw in primary lenses rather than expect the customer to go and tack on some aftermarket universal $2000 correcter??
Is lense user removable and we are just waiting for alternative primary from JVC?
post #12 of 33
Yes, the idea is to use the full vertical resolution and then correct with a lens, that is with a HC setup.
Yes it would make sense for the PJ manufacturer to offer something like that.
From what I have read on the forums here the JVC lens is not removable. Generally Even the PJ manufactures that offer CIH scope functionality use a second lens in front and not an alternative primary lense.
post #13 of 33
I was about ready to buy an RS1 untill I found out it did not have a stretch mode.
Key digital has an inexpensive switcher/ scaler which includes a stretch mode.
Has any one tried this? its much less expensive than an outboard processor.
post #14 of 33
Do you have a link? If so, please post it...
Mark
post #15 of 33
Mark
Here is the link http://sewelldirect.com/4x1-hdmi-switch-processor.asp
It looks like it does the stretch
post #16 of 33
I don't see where it says it does vertical stretch. It scales a lower res input to your PJ's resolution, it switches hdmi, it's also not cheap at $1000. Does not mention whose chip it uses either.
post #17 of 33
Is vertical zoom the same as vertical stretch on the key digital switcher/scaler?
post #18 of 33
post #19 of 33
I would Ass-U-Me so, but then I have not seen the actual product...
Mark
post #20 of 33
Yes, the keydigital does the vertical stretch. There is a thread on it.
post #21 of 33
Does anyone know if using the Lumagen Vision HDP with the RS-1 will allow the HD signals to be vertically stretched so an anamorphic lens will be able to expand the picture to 2.35? If so, how is this done? Thanks
post #22 of 33
Yes, the Lumagen HDP/HDQ/PRO scalers can vertically stretch SD and HD to fill the 16:9 panel, and the lens will either squish it back down by 33% (VC lens) or expand it horizontally by 33% (HE lens). It's just a matter of setup of the scaler.
post #23 of 33
In regards to the RS-1, if a processor such as the Key Digital is used to achieve the vertical stretch, is the onboard Gennum video processing in the RS-1 bypassed? Would you then be using an inferior video processor, or will the Key Digital simply do the stretch and nothing else?
I'm a bit confused, as I understand that the Gennum in the RS-1 is outstanding. I really want to be able to use this for 2.35:1
It is tough to swallow, adding $600 just to stretch the image, but if it also hinders the quality, then it is not worth it to me.
Can someone attempt to clarify this?
Thanks alot.
post #24 of 33
Given the seemingly unfixable oversaturation issue with the RS1 /HD1, it looks like I might be forced into buying a VP to gain saturation control. If I'm going to spend the money on a VP, going to a CIH system becomes an option I hadn't previously considered. With that said, I have a couple of basic questions for you guys...
My RS1 is mounted at the min throw and using max zoom to achieve the largest 16:9 image I can given my space constraints. Will this be an issue with using an add-on CIH lens?
My 16:9 screen is 83.5" x 47". Does this mean I could go to a 110.5" x 47" screen given the same throw and zoom setting if I used a HE lens?
What lens are you guys considering with this PJ? Any recommendations for a VP (under $2k) which will do at least as good of a job scaling as the RS1 does independently?
Sorry about the newbie questions... I've never had any interest in going CIH before I realized I might be forced into buying a VP.
post #25 of 33
Thanks alot.
Unfortunately, you would be using the inferior processor to achieve the desired stretch. While the cheap VP idea sounds great, it's not worth giving up one of the better attributes of the RS1 to do so IMO.
post #26 of 33
It says it does letterbox which is vertical stretch. I don't know what chip it has and there is a power buy on AVS forum for 599.
I have looked at outboard processors and the average price seems to be around 3000 dollars and manufactures which use the Genum chip charge 5000 dollars or more which shows you what a shame it is that JVC did not incorporate the function of the Genum chip to stretch a 2:35 image.
John From Integrity Home Theater mentioned to me that he is bringing one in house to test
I want a letterbox stretch function because I want to set up a CIH screen and without it the anamorphic lens I have is useless
post #27 of 33
Be carefull with the word letterbox. It is NOT always used to mean vertical stretch. That aside, this unit, according to its manual, does the proper stretch.
post #28 of 33
This unit says to have pass-through mode as long as the input equals the output.
So if you are feeding it a 1080i/60 from a HD-DVD, do the vertical stretch and then output this as 1080i/60. Wouldn't then the RS-1 onboard video processor take over the duties of de interlacing, rescaling and such?
post #29 of 33
Someone please correct me if I'm wrong:
If the unit is in pass-through mode, you won't be able to use the stretch function.... the image will need to be processed by the VP for the stretch to happen.
post #30 of 33
My understanding of this unit is yes, it does provide the "scaling" we need for CIH, but only for SD. You will still need an external scaler for HD at this time...
I would have to agree. This sounds like the "through" mode on many projectors...
Mark
