help recover
post #1 of 5
Greetings,
After an accident some of my valuable files were gone on NTFS drive. Can some utility recover them? I however wish to use the most reliable one as they are really important.
post #2 of 5
Originally Posted by terry brian View Post
Greetings,
Try this its a good program:
http://www.smartpctools.com/ntfs_recovery/index1.html
post #3 of 5
Hi
I can recommend you Active@ Undelete tool. It is powerful. Also, it's latest ver can boot from it' bootdisk to recover data even if OS is corrupted
post #4 of 5
You can recover your valuable file with ARAX Disk Doctor. The tool is a good one and should help
post #5 of 5
Active@ Undelete seems to be working quite OK, as the files were gone a time ago but still it managet to locate them and bring back. Thank you very much !
