AVS › AVS Forum › Other Areas of Interest › Camcorders › Canon HV10: PAL<->NTSC via firmware?
post #1 of 3
Long story short, I've ended up with a US-version NTSC Canon HV10 instead of a PAL one (sigh). I do plan on using it for some SD content.
I assume the difference is purely the firmware. Is there a way to convert the camera?
post #2 of 3
I believe that the difference is a lot more than just firmware. There is absolutely no way that you will be able to convert it from NTSC to PAL standards.
Dave
post #3 of 3
Only Canon higher models have this upgarde facility, I believe
  Back to Forum: Camcorders
