Originally Posted by
ballers34
Hello all I'm pretty new to the htpc world having built my first one a few weeks ago....I have been backing up my 3D blu rays and I cant seem to get them to play properly on tmt5. I get about 5-10 mins in and tmt stops responding and I have to close the program...this has happened with Avatar and Tron...I have tried playing it as an iso and has a regular rip file but no luck I'm using amd 6870 graphics card with the lastest driver update from amd...Any Help would be greatly apprieated
Do you have a BD burner and a 50Gb BD_RE in that PC as well? If so burn one of your rips and see if that works.
Also, you don't mention if the originals have the same issue. What OS are you using? Have you turned off any AV type stuff, stopping that from interferring with the transfer? How are you transfering, HDMI cable, HDMI over cat 5, over the air? What else is running on the PC when it crashes?
Also, you might want to go look in the HTPC section and see if anyone else has had your issue.
Seggers
