Log in hopes someone can see if mistake is coming at Imgburn. Thanks!
ImgBurn Version 2.5.5.0 - Log
; Thursday, 20 October 2011, 14:12:13
I 13:51:27 ImgBurn Version 2.5.5.0 started!
I 13:51:27 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
I 13:51:27 Total Physical Memory: 8,352,752 KB - Available: 5,051,280 KB
W 13:51:27 Drive E:\\ (FAT32) does not support single files > 4 GB in size.
I 13:51:27 Initialising SPTI...
I 13:51:27 Searching for SCSI / ATAPI devices...
I 13:51:27 -> Drive 1 - Info: TSSTcorp DVD+-RW TS-H653G DW10 (D
(ATAPI)
I 13:51:28 -> Drive 2 - Info: HL-DT-ST BD-RE BE12LU30 4261 (J
(USB)
I 13:51:28 Found 1 DVD±RW/RAM and 1 BD-RE!
I 13:51:51 Operation Started!
I 13:51:51 Building Image Tree...
I 13:51:51 Calculating Totals...
I 13:51:51 Preparing Image...
I 13:51:51 Contents: 50 Files, 18 Folders
I 13:51:51 Content Type: BD Video
I 13:51:51 Data Type: MODE1/2048
I 13:51:51 File System(s): UDF (2.60)
I 13:51:51 Volume Label: [Not Configured]
I 13:51:51 Size: 4,745,525,837 bytes
I 13:51:51 Sectors: 2,317,184
I 13:51:51 Image Size: 4,746,772,480 bytes
I 13:51:51 Image Sectors: 2,317,760
I 13:51:51 Operation Successfully Completed! - Duration: 00:00:00
I 13:52:53 Operation Started!
I 13:52:53 Building Image Tree...
I 13:52:55 Calculating Totals...
I 13:52:55 Preparing Image...
I 13:52:55 Contents: 50 Files, 18 Folders
I 13:52:55 Content Type: BD Video
I 13:52:55 Data Type: MODE1/2048
I 13:52:55 File System(s): UDF (2.60)
I 13:52:55 Volume Label: AVCHD-20111020-134641
I 13:52:55 Size: 4,745,525,837 bytes
I 13:52:55 Sectors: 2,317,184
I 13:52:55 Image Size: 4,746,772,480 bytes
I 13:52:55 Image Sectors: 2,317,760
I 13:52:57 Operation Successfully Completed! - Duration: 00:00:03
I 13:52:57 Operation Started!
I 13:52:57 Source File: -==/\\/[BUILD IMAGE]\\/\\==-
I 13:52:57 Source File Sectors: 2,317,760 (MODE1/2048)
I 13:52:57 Source File Size: 4,746,772,480 bytes
I 13:52:57 Source File Volume Identifier: AVCHD-20111020-134641
I 13:52:57 Source File Volume Set Identifier: 3F546E9A00235D20
I 13:52:57 Source File Application Identifier: ImgBurn v2.5.5.0
I 13:52:57 Source File Implementation Identifier: ImgBurn
I 13:52:57 Source File File System(s): UDF (2.60)
I 13:52:57 Destination Device: [0:0:0] HL-DT-ST BD-RE BE12LU30 4261 (J
(USB)
I 13:52:57 Destination Media Type: BD-R (Disc ID: VERBAT-IMc-000) (Speeds: 2x, 4x, 6x, 8x)
I 13:52:57 Destination Media Sectors: 12,219,392
I 13:52:57 Write Mode: BD
I 13:52:57 Write Type: DAO
I 13:52:57 Write Speed: 4x
I 13:52:57 BD-R Verify Not Required: Yes
I 13:52:57 Link Size: Auto
I 13:52:57 Lock Volume: Yes
I 13:52:57 Test Mode: No
I 13:52:57 OPC: No
I 13:52:57 BURN-Proof: Enabled
I 13:52:57 Write Speed Successfully Set! - Effective: 17,982 KB/s (4x)
I 13:53:16 Filling Buffer... (40 MB)
I 13:53:17 Writing LeadIn...
I 13:53:18 Writing Session 1 of 1... (1 Track, LBA: 0 - 2317759)
I 13:53:18 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2317759)
I 13:57:43 Synchronising Cache...
I 13:57:46 Closing Track...
I 13:57:47 Finalising Disc...
I 13:57:58 Exporting Graph Data...
I 13:57:58 Graph Data File: C:\\Users\\dave\\AppData\\Roaming\\ImgBurn\\Graph Data Files\\HL-DT-ST_BD-RE_BE12LU30_4261_THURSDAY-OCTOBER-20-2011_1-52_PM_VERBAT-IMc-000_4x.ibg
I 13:57:58 Export Successfully Completed!
I 13:57:58 Operation Successfully Completed! - Duration: 00:05:00
I 13:57:58 Average Write Rate: 17,558 KB/s (3.9x) - Maximum Write Rate: 18,504 KB/s (4.1x)
I 13:57:58 Cycling Tray before Verify...
W 13:58:08 Waiting for device to become ready...
I 13:58:22 Device Ready!
I 13:58:23 Operation Started!
I 13:58:23 Source Device: [0:0:0] HL-DT-ST BD-RE BE12LU30 4261 (J
(USB)
I 13:58:23 Source Media Type: BD-R (Disc ID: VERBAT-IMc-000) (Speeds: 2x, 4x, 6x, 8x)
I 13:58:23 Image File: -==/\\/[BUILD IMAGE]\\/\\==-
I 13:58:23 Image File Sectors: 2,317,760 (MODE1/2048)
I 13:58:23 Image File Size: 4,746,772,480 bytes
I 13:58:23 Image File Volume Identifier: AVCHD-20111020-134641
I 13:58:23 Image File Volume Set Identifier: 3F546E9A00235D20
I 13:58:23 Image File Application Identifier: ImgBurn v2.5.5.0
I 13:58:23 Image File Implementation Identifier: ImgBurn
I 13:58:23 Image File File System(s): UDF (2.60)
I 13:58:23 Read Speed (Data/Audio): MAX / MAX
I 13:58:23 Verifying Session 1 of 1... (1 Track, LBA: 0 - 2317759)
I 13:58:23 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 2317759)
I 14:05:40 Exporting Graph Data...
I 14:05:40 Graph Data File: C:\\Users\\dave\\AppData\\Roaming\\ImgBurn\\Graph Data Files\\HL-DT-ST_BD-RE_BE12LU30_4261_THURSDAY-OCTOBER-20-2011_1-52_PM_VERBAT-IMc-000_4x.ibg
I 14:05:40 Export Successfully Completed!
I 14:05:40 Operation Successfully Completed! - Duration: 00:07:17
I 14:05:40 Average Verify Rate: 10,607 KB/s (2.4x) - Maximum Verify Rate: 12,621 KB/s (2.8x)
I 14:12:12 Close Request Acknowledged
I 14:12:12 Closing Down...
I 14:12:13 Shutting down SPTI...
I 14:12:13 ImgBurn closed!
