HDV to BD
Softwares:
1. HDVsplit - capture HDV to computer
2. Premiere Pro 2 - edit hdv video and output elementary streams
3. Photoshop CS2 with Scenarist Designer plug-in - BD menu creation
4. Scenarist HDMV - BD authoring
5. ImgBurn - burning BD image
6. PowerDVD Ultra - playing BD disc
Simple Workflow:
1. Capture HDV to computer
2. Edit video and output final video from Premiere Pro 2. In order to create BD, you must output elementary streams, i.e.: 1 video stream (mpeg 2 format) and 1 audio stream (ac3 format)
3. Design BD menu using Photoshop CS2 and export using Scenarist Designer plug-in
4. Import all materials (video, audio, menu) to Scenarist HDMV to do authoring
5. Create BD image from Scenarist HDMV
6. Burn BD image using ImgBurn
7. The disc can be playback on PC or BD player that compatible with BDR or BDRE.
