You can use Nero to create a UDF 2.5 .nrg file that ImgBurn can use.
Just change the 'target' when you have your BD ready to burn from the Sony Burner to an 'Image File' (I forget the actual term they use).
No idea about Roxio.
You can create an image file with DVDit Pro HD that should also burn with ImgBurn.
