MozartMan and Creator,
Would you try one more experiment to see if either of your respective workflows will produce a BDMV video in sync with the audio using this file.
1.) Rename the ts file extension to mpg and play it back with Windows Media Player or another player to confirm the source file audio is in sync with the video.
2.) Demux the ts file using Elecard Xmuxer Lite, into elementary streams mpv and ac3.
3.) Mux the elementary streams back together into a ts file once again using Elecard Xmuxer Lite.
Playback the file. Don't use the Elecard for this, use another player. Move ahead to the part where the bald headed guy with the hangover is muttering "This is NOT pretty."
Did the audio remain in-sync with the video? For me, the audio is ahead of the video by 1/2 second at this step of the workflow.
. Would you know if this may be because of the H.264 profile or does the PS3 not like H.264 w/1440x1080 resolution?
