Originally Posted by fatherom
For HD-DVD authoring, 720P MPEG-2 TS files are usable, as well as 1088i files. After saving from VideoReDo as a program stream, the files are HDPatch'd before loading them in Ulead. This tricks Ulead, so it doesn't attempt to re-encode the files. In the case of 720P, the resulting EVO files are then HDPatch'd again before burning.
Would 720P or 1088i files work with the new Roper/Brajesh master workflow?
Chris
Chris
I believe so. A little bit off topic, but Canon HDV pro cams like the XL-H1 and XH-A1 output in a format called 24F. There's been a lot of confusion about that since the beginning because some NLE's would not recognize it. But basically what it is, is 24 progressive frames laid to stream, with repeat flags added. That's really pretty nice because it intercuts with 60i on the same timeline, plays equally well when output as 24p or 60i. Some NLEs and mpeg editors see and use the flags, and report the 24F output as 60i (59.94). Others ignore the flags and report the stream as 24p. So some people have been arguing that it has no 3:2 pulldown frames, and that's true. Some argue that 24F doesn't have the flags because either their NLE doesn't use them, or because 1080p24 is true progressive and wouldn't ordinarily have them, whereas 480p24 are progressive frames segmented into 60 fields with pulldown. But my editor says that 24F Canon does have the flags. And it intercuts with 60i on the same timeline, no problem.
So I'm going to climb out on a limb and say that I think an AVCHD/mpeg2 authored red laser disk will play 1080p24 progressive, if the stream contains pulldown flags like the Canon 24F.
Some other cams from Sony and Canon use either progressive segmented frames, or true 24p frames as well. Whether they play friendly on the AVCHD/mpeg2 authored red laser disk, I haven't tested.
I really wanted this to work.
