Hey all, great stuff on this forum btw.
Im in the finishing phase of my DIY pj and although I do realize that most of the people who post here have Brand-name pj's, I thought I should still ask the experienced.
I have a pj that has a 210 triplet that I am thinking about projecting a 80" diag image from 10' away that is ceiling mounted. It puts out about 300-400 lumens on the wall, nothing compared to commercial stuff, buts its OK w/o any ambient light and quite watchable in my test setup.
I have been going over most of the topics and I see some interesting things mentioned about silver metallic, neutral grey and high contrast white paints. Unfortunately, where I am we cant find most of the paints that you guys reference (Behr, shermin, folkart etc.), but I am still thinking about doing a DIY paint job on a BOC screen that will be 1.90 m by 1.15 m (approx. 75" x 45").
I read in the beginner guide about:
2 coats of white flat mat primer
2 coats of neutral grey flat
A coat of polyurethane mat top coat
and was thinking about going with this. I have no idea how I will get the right grey mix because I cant find those brands here, but still, will this be watchable with low lumens? Or, should I just go with a matte white and top coat of polyurethane mat?
Any recommendations on what type of paint mixtures I should look for or anything that you guys could direct me towards would be great.
Thx.
Thx.
(yup, regular photon bombs), one will be behind the screen, and completely blacked out, the other is along the long side of the room perpendicular to the screen. On the wall opposite the longest glass block wall, are two doors leading to a well-lit dining hall/cafeteria.
