AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Chicago, IL - OTA
Chicago, IL - OTA - Page 366
post #10951 of 11590
25.2 is back, this time with a bug that seems to read "Tellos Digital Television" with two L's in "Tellos."  The PSIP name is Telos with one L.  I don't know whether it's the channel whose home page is http://www.telostv.com or not.
post #10952 of 11590
I live in the Chicago area (Hinsdale) at these coordinates which are slightly Southwest of the city: 41.822022, -87.920108
The dwelling is an apartment building 20 stories tall.
My apartment is 15 stories up on the West side of the building, the exact opposite direction as the towers in Downtown Chicago.
I can only have an indoor antenna. Any suggestions (other than move)?
I asked Solid Signal this question several times and never got a reply. Is this too difficult to do?
post #10953 of 11590
I think you can do well with the Winegard Sharpshooter SS-3000:
http://www.google.com/products/catal...d=0CEMQ8wIwAQ#
It's more expensive, but over at TvTechnology, Doug Lung, a very well respected engineer, gives this one a thumbs up. The 100' height above terrain will give you the signal strength.
post #10954 of 11590
Originally Posted by hvs10trk View Post
I used to work at that facility in Rolling Meadows. It was a receive site back the MediaOne/ATT days. I believe it's still a backup site. There are OTA receive antennas at the top but those are a back up as well. There was typically 1 tuned antenna per channel they were picking up. That was a nicely setup facility back in the day.
Heh. Going off topic for a second, Comcast disconnected all the cables from the antennas at the DeKalb/Sycamore head end...the tower is only used for cell phones now. They got rid of all their receivers on top of that, and even worse, we're one of only two Comcast headends in the country that doesn't have redundancy.
This spring, Comcast will put in fiber from Rockford to DeKalb to complete the ring from Chicago to Rockford to DeKalb (right now we just get 1 fiber link from near Downer's Grove to St. Charles to us, and when that got sliced by a construction worker last year, we had nothing, nada, no phone, Internet or cable out here for 23 hours). Then we'll also be able to get the Rockford stations in HD, instead of a standard def, low bandwidth feed we have now.
To me, it's just silly they wouldn't use one antenna and keep their receivers as a backup. Heck, D* and E* still use OTA as primary or backup, right?
post #10955 of 11590
Everyone is generally fed fiber and OTA is their backup. They probably have a master site for OTA reception. E* is the only one we don't feed via Fiber.
post #10956 of 11590
I wonder if this is coming to Fox 32.
-from northpine.com
NATIONAL:
News Corporation, owner of FOX, has announced plans to launch a national spanish-language broadcast network called MundoFOX this fall with stated plans to reach 75 percent of the U.S. at launch. There are numerous other spanish-language networks, but few have the backing of a major company like News Corp. or such wide distribution. Affiliates have not yet been announced. News Corp's owned-and-operated stations include KMSP/FOX 9 and WFTC/My 29 in Minneapolis. (1/24/2012)
post #10957 of 11590
-from northpine.com
NATIONAL:
I would hope 50.2 instead. We'll see.
post #10958 of 11590
Why would 50.2 be preferable to 32.2?  Other than "I'd rather see the station that I watch less be the one to sacrifice the bits for a subchannel," I can't see any reason for a viewer to consider one better than the other.
post #10959 of 11590
Possibly viewers watching NFL on FOX 32 would appreciate not having artifacts introduced by a dot2 while viewers of Law and Order reruns on 50 could tolerate artifacts from a dot2.
post #10960 of 11590
George and Dattier have it, exactly. And given MNTV (owned by Fox) is on 50.1, and has scripted programming (usually slow scene changes rather than fast-action sports), it would make perfect sense to put it there.
post #10961 of 11590
FOX uses a technology called a splicer that has fixed bandwidth for HD and a subchannel. The bandwidth is already carved up. I note the sub will have to be SD though
post #10962 of 11590
Yep, the NFL will look the same as it does now even if they add a sub.
post #10963 of 11590
Having an ear close to the situation, both channels are getting a sub, different services! That's all I can say..... and it isn't official. Cough cough! :-)
post #10964 of 11590
If Snooper and Bob are right, and if the technology to which Snooper refers is on use on WPWR as well as WFLD, then it doesn't matter whether MundoFOX turns up on 32.2 or 50.2.
post #10965 of 11590
It does matter, because if one is broadcasting in HD, it would have to go to 50.2. You can at least do widescreen on WPWR's equipment, I'm guessing, much like 5.2 does.
post #10966 of 11590
They have different equipment?  OK, thanks for explaining that.  I'm surprised, especially that the better equipment would be at WPWR rather than WFLD.
Even so, will MundoFOX be in HD anyway?
post #10967 of 11590
You can technically do two 720P channels in one spot, look at WLS.
They have different equipment?* OK, thanks for explaining that.* I'm surprised, especially that the better equipment would be at WPWR rather than WFLD.
Same equipment, different racks! LOL Your probably seeing a bit rate difference.
Back into silence mode! Speculate away!
post #10968 of 11590
FOX probably has what it takes (out of the rest of the OTA networks, ignoring Telemundo/NBC) to launch a Spanish network. It's already got soccer contracts for its cable outlets, for one, and MyNetworkTV scored well initially in Hispanic markets with its telenovelas. But I hope they managed to learn some lessons from the MyNetworkTV failure, both about competing with yourself and about ambition/Murphy's Law. I remember that MyNetworkTV was intended to be profitable from day one (and it was on course to, until the actors unionized).
Of course, competing with yourself may not be as big of an issue here as it was with MNTV. If two markets are mutually exclusive (like men's razors vs women's razors), you don't really need to worry too much about self-cannibalization. So, how separate are the two markets? A majority of English speakers in the US probably do not know Spanish well enough to follow Spanish TV, but I suspect that a larger percentage (maybe even a majority) of the Spanish speakers in the US know enough English to follow English TV. But I don't know enough about the TV watching habits of people (of either language) who watch Spanish TV to be able to conclusively state that.
post #10969 of 11590
RIP: Don Cornelius (1936-2012).
post #10970 of 11590
dtt-901 sees no psip for 23.x , 26.x and 48.x
can some one pusha button please?
kd9fz
comments, criticisms and questions of sanity are most welcome
post #10971 of 11590
Started out Soul Train on WCIU-TV! And, he did double duty at the time, doing "Black's View Of The News"...
http://fuzzymemories.tv/#videoclip-3191
Just below the camera was a speakerphone, and a microphone!
And then it got moved to WGN, and the rest was history.
post #10972 of 11590
kd9fz
9 am and the psip for 23.x, 26.x, and 48.x are back
thank you
kd9fz
post #10973 of 11590
WPVN 24 has been down all day.
post #10974 of 11590
They must have been testing the Trump Tower location recently. I had been picking up the station with the antenna pointing tward the city. Now I have to point it back to Schaumburg to get a signal.
post #10975 of 11590
[WPVN] must have been testing the Trump Tower location recently. I had been picking up the station with the antenna pointing tward the city. Now I have to point it back to Schaumburg to get a signal.
I doubt that that's the reason.  If they were broadcasting from Trump Tower, surely I'd get them here with our antenna pointing from the Northwest Side toward the old stick site at the Prudential Building, which does fine with stations atop Willis Tower or the Hancock Center.  But I haven't been able to pull WPVN in for weeks.
Meanwhile, W25DW, WOCK, and (even though I'm north of Dakin Street) WCHU have been coming in more reliably than before.
post #10976 of 11590
I doubt mundoFOX will succeed if they fill their programming with unnecessary racial stereotypes and portrayals like they're currently doing with the animation domination, its almost unbearable to watch because of it.
Anyway is anyone having problems with WGN today? Just completely lost reception on it (and in a weird way) its usually the strongest signal here, everything else I normally get with the terk HDTVi is still coming in.
post #10977 of 11590
Bulls game is on atm.
post #10978 of 11590
WGN coming in clear for me
post #10979 of 11590
Having three Seth MacFarlane productions will do that.
post #10980 of 11590
It'll come in clear and then go right back out, weird
I really think he has a problem with race or something, what is the point in having persistent racial stereotypes and portrayals across all shows and in every single episode and its not just those shows even napoleon dynamite has them.
