Originally Posted by FedEx227
Hey just curious if anyone is having problems getting ABC (7.1-7.3) or WGN (9.1)? Just a few days ago these stations turned to black and now I can't get a signal through them, which is odd because I can pick up CBS, NBC, WTTW, etc. just fine. Just these two are black, and not even low signal, NO signal what so ever.
Wondering if anyone else has had this problem in the past few days? Or if someone can recommend a good fix.
I'm on an LG 32", using the built in tuner, no extra HD antennas.
Also, it's weird because I didn't move anything and have reconnected everything and made sure the connections are all good and they appear to be.
Not here, but if they made a software change at the stations, you may have to rescan. See what happens.
