AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Chicago, IL - OTA
Chicago, IL - OTA - Page 270
post #8071 of 11584
Originally Posted by goaliebob99 View Post
They dont, The antenna is high enough and far enough back that they really dont affect anything. Also there is a nice sized whole in between there that the signal goes through. I keep hoping that one day lightning will strike that tree though so that way there defiantly wont be any issues with the trees.
EDIT: the trees look alot closer in the photo than what they really are. That antenna is at least 30 feet from those trees.
Sorry, gotta hit the "Gong Show" gong on this one. ;-) I have trees farther away from you, and they most certainly affect my reception when it is windy. They're about 100' away from me.
post #8072 of 11584
Originally Posted by judget View Post
got a question for you.. i have a friend who lives downtown in a single family home... they live near the hancock... they have no tv currently... if they installed an outdoor antenna like you state and get the dtv box will they get the chicago stations... i tried for them the dtv box and an amplified indoor antenna... no luck... no signal on any chicago station....
Originally Posted by sebenste View Post
An amplified box near the Hancock would cause signal overload/massive multipath. An outdoor antenna without an amplifier should work with a digital converter box.
Unless judget's friend plans to do DX'ing, a small VHF/UHF combo antenna is all that's needed for Chicago. I rarely saw large antennas on peoples' homes in the city limits. One place I know has an antenna that's around 30 years old and it still works at getting all of the stations from the Sears Tower & John Hancock (including VHF).
post #8073 of 11584
Hi everyone. Sorry to ask such a 'newbie' type question, but I dont live in Chicago, and am hoping someone there might be able to suggest a course of action for me. My fiancee has a place up in Lakeview area, near Belmont. 8th floor south facing apartment with a clear line of sight to "Sears" tower, blocked view of John Hancock I think. She also has comcast. As we are hardly there anymore, we want to downgrade her cable TV (eliminate it) to save money. The choices that popped into my head are either OTA or Clear QAM. She does not have an HD set, so a tuner of some sort is in order.
If I were to go the OTA route, according to tvfool.com, it appears I can get by with a pretty small indoor antenna. Would you all agree? Or would it be better to try the clear QAM route? We are going to maintain cable modem service in the apartment, so digital programming should still come through if Comcast acts anything like Charter in my area.
Sorry to incorporate QAM talk in an OTA thread, but I figured I would only post in 1 Chicago thread and since I am guessing OTA is the better option, I picked this one!
post #8074 of 11584
I'd suggest this:
http://www.avsforum.com/showthread.php?t=1136626
It's the most inexpensive, recent, standalone model ATSC/QAM tuner - so you can try both methods and see which works better.
And yes, you should use a simple, un-amped UHF/VHF model antenna from where you're at.
(edit: forget that link - it doesn't work, for some odd reason, even though I know it's correct. Maybe because it hasn't been active in a couple of weeks. They ask you to "search", so I guess you can do it right from that link if you'd like. Just search under "Centronics" (ZAT 502HD), either there, or directly in the "HDTV Technical" forum, where it's at.)
post #8075 of 11584
Not mine, at least not that I have seen. The majority of the stations that I get dont breakup, so if there is any, then its not noticeable.
post #8076 of 11584
I'd straighten them out, but that tree is enemy #2. I would still check to make sure the connections are good up there, even if all the stations are of normal signal. You never know what you might find.
Sounds like this weekends project
post #8077 of 11584
any thoughts as to which antenna designs are not only good signal catchers but best at withstanding the harsh suburban rooftop environment?
my current chimney mounted CM3016 Suburban Advantage has some missing and bent rods (director reflectors) (weather squirrel birds?).
No tuning problems yet but given this sale , i'm want to replace it.
post #8078 of 11584
The last few days, at times when we can receive WOCK-LD, subchannel 13.3 is no longer there.  It's not black and silent with PSIP data like 13.4 but rather without signal like 56.2.
Is anyone still receiving 13.3?  Is it still Adtec D?
post #8079 of 11584
Originally Posted by dattier View Post
The last few days, at times when we can receive WOCK-LD, subchannel 13.3 is no longer there.* It's not black and silent with PSIP data like 13.4 but rather without signal like 56.2.
Is anyone still receiving 13.3?* Is it still Adtec D?
I rarely got them on analog, due to the exteme nulls to the east & west to protect WZZM in Grand Rapids & WREX in Rockford, IL. Both stations are broadcasting on 13 for digital. Still don't get them on digital on 4 & not sure if I'll get them on 30 (if approved). BTW, it's WOCK-CD, not-LD. Trip in VA got it wrong as well. Stations with -CD in their call letters are a Class A digital station, and have protection, unlike stations with -LD in the call letters, that have no protection from interference or their channel. Don't believe me that WOCK-CD is their offical call letters; just check the link to go to the FCC site.
Wish I had the spare money to get that antenna. I would like to replace the antenna I have now and get separate VHF & UHF antennas. That is a good price for that antenna. But I'll probably end up paying more when I can afford to get a new one, as I'm currently out of work.
post #8080 of 11584
As long as you don't want channel 4 (WOCK-CD, which is applying to move anyway), get that antenna. It's great! You won't regret it.
post #8081 of 11584
OK; that makes more sense, because the analog stations were class A's, designated WOCH-CA and WOCK-CA rather than -LP.
Don't believe me that WOCK-CD is their offical call letters[... ?]
Why are you expecting a dispute?
Meanwhile, can anyone answer my original question and confirm whether 13.3 is gone?
post #8082 of 11584
Sorry I can't help here. I've never been able to get it,anyway.
post #8083 of 11584
wockcd (4) > subs 1 & 2 contain video; 3, & 4 are dark, but you knew that.
post #8084 of 11584
Well still no luck with WCIU. Swapped out the antenna with a channel master 4228 and saw a slight improvement but still no lock. I did straighten out the elements on the antenna though. Next step would be to go with a 15 foot beast, What's the best antenna out on the market today? I know beaming through those trees dont help, but I just dont get what would happen that would WCIU to go out like that. I did replace all of the connectors and they are weather proofed with the rubber boots. None of my connections looked bad, but I re crimped them anyhow. Still no luck though.
post #8085 of 11584
Hey Goalie,
What about next to the house where it comes in, and also where it comes into the TV? And any connectors inbetween? #1 issue tends to be connectors, even though I know you're a DTV geek like me , I don't want to overlook the obvious!
I mean, with a CM 4228 on the roof, that signal should be blasting in. OK, weird thought: turn the antenna *south* and see if you can get WCCU. If you can, there's your issue. You'll need to find a "hot spot" on your roof to get WCIU, if you can pick up WCCU.
The 4228 is THE best for frequencies around WCIU. Overall, I claim this is:
http://www.amazon.com/Winegard-HD820.../dp/B001DFS4BI
post #8086 of 11584
We call it conditional access.
post #8087 of 11584
Hey Goalie,
OK a couple of questions, Is there any difference between the old style 4228 and the new one?
Yep I checked all connections, basically I went through the install from the antenna all the way to the tv with everything in between. Im going to try a few more things.
post #8088 of 11584
With all due respect to Gilbert, I suggest this makes more sense
(and is what I'm using):
http://starkelectronic.com/winegard.htm#HD7695P
There's no reason anymore for a huge all-channel (2 - 51) in Chicagoland,
these Winegards work great and are physically small since they only go down to Ch 7.
Easier to put up, lower wind loading , and no long elements for a fat bird to sit on and break off
post #8089 of 11584
Good job on going end-to-end on the checking. The difference between the old and the newer 4228 is that it takes off 1-2 dB on the UHF, and gives you relatively good performance on VHF-HI (channels 7-13). A little sacrifice is made for the UHF channels, but it's not bad enough to raise my eyebrow today, although it did at first. If you are 30' up on the roof, it should make no idfference to you. You should be able to lock WCIU line-of-sight. It pegs my signal meter in my 1-story attic near a river valley on the far NW side of DeKalb.
I still think it could be WCCU. This past week, I lost about 25% signal on WGN-DT. It's still well above lock level, so I have no issues. What happened? WMTV-DT 19 in Madison, WI went from 56 kw on a side-mounted antenna to 155 kilowatts on a top-mounted one this past Wednesday or Thursday.
post #8090 of 11584
__________________
Gilbert
The 7698 is comparable to the 8200 on UHF and high-VHF without the added mass and expense of low-V elements.
Since there are only a couple dozen markets with any full-service stations on low-V, the 8200 has very limited application. Philadelphia, Memphis, Las Vegas, Davenport, Bangor, and Roanoke are a few of the cities that have either a major network or PBS station on low-V.
post #8091 of 11584
Noticed during most of today that WBBM's signal dropped to under 60% when it's usually in the 85% range. I was seeing drops and that never happens. Now in the last half hour it's back to normal. Anyone know what's going on or is it just something here? Reception on WLS 7 was normal (and with a stronger signal than 12 - opposite of usual) so it's not noise related.
post #8092 of 11584
Real strong tropo tonight. Might have something to do with it.
Been watching WYIN steadily for the last couple of hours, and that's like 75 miles away from me. Also getting a couple of South Bend stations.
Actually getting a better signal with my indoor antenna, because of the shorter coax.
(edit: Getting Polnet for the first time ever with the rooftop antenna on the Sony DVR in the other room now, too!)
post #8093 of 11584
True, but boy, is it fun for DX'ing! You are right, of course; the 7698 is the 8200 without the VHF-LO part of the antenna.
post #8094 of 11584
The southern portion of the Grand Rapids/Kalamazoo market of Michigan has WGVK (simulcast of WGVU on RF 11) on RF 5. I don't know if anyone along the lakeshore get that station. I know I don't simply because I'm not close enough to the lakefront. Also, I don't have a rotator. So my antenna is permanently mounted to point toward Chicago with only a 3° difference the signals coming from the Sears Tower & the John Hancock.
post #8095 of 11584
I noticed a week or so back that the 8200 you installed here at Willow Creek is still there.
Hasn't blown away yet.
post #8096 of 11584
I haven't had any luck with WGVK, but I have received WGVU, WTLJ, and WZZM numerous times in Northbrook.
post #8097 of 11584
Last night when I was watching WCIU, I noticed that the schedule for 26-1 was still on the old schedule, since when I turned in at 10:30, it still said "George Lopez". But with the new schedule in effect, "The King of Queens" was on at 10:30, so I just wanted to let someone know that WCIU's schedule for 26-1 may have to be looked into. Thanks.
post #8098 of 11584
Cool. They can get Milwaukee and Rockford with no problems. Before WBBM went to channel 12, they always got a 90% signal from them on channel 3. It's just on a mount that's held down by sandbags, too!
post #8099 of 11584
WLS-DT has applied to keep channel 7 on for 6 more months.
https://licensing.fcc.gov/cdbs/CDBS_...um=1&exhcnum=2
They have three phases of construction for getting channel 44 to full power. One, getting 44 on the air at decent power...which is done. #2, going 1 million watts on Hancock, and then step 3...although not filed yet...almost certainly 1 million watts from Sears. To do this, they want to have 7 still operating because the 1 megawatt signal from Hancock might overload nearby viewers (scratches head). Anyway, they are actively getting ready for a new high power UHF transmitter on Sears. The document above is an interesting read; nothing new here for those following the saga, but they speak of their progress.
post #8100 of 11584
You can have too much signal ... but once they have 1 megawatt from Sears/Willis won't they have the same problem? Or is Wacker less residential than Hancock? If the problem doesn't go away will they want channel 7 forever?
Seems like an excellent reason to have a null off the bottom of the antenna so just enough power goes down without flooding the receivers. The null there should take care of the problem.
