Originally Posted by
WillieAntenna
Thanks for getting back. Wow getting Milwaukee with that U-75R you about 65 miles from the Milwaukee antenna farm on north farside in Shorewood that good. Have you been pokeing your head in BB or CC this weekend someone said there is some new units out this weekend DVD with ATSC tuners don't know which brands, but I see CC in your town has the Sammy 260 in stock now.
-Willie
I think I'm probably only getting Milwaukee good because the leaves are off the trees across the way and it was winter (cold). They must be very high-powered. I think I was only able to get a couple of channels late last fall, when I first got the antenna up. But fortunately, the one I got most regularly then was 36-1. I really didn't get that one so much when it was colder, but now that it's warming up, I'm getting it again (don't know why that is). Even still, it's usually only at night (same as the others all winter). Actually, that PBS-HD channel is the one I'd want most anyway - all the others are just clones of the Chicago stations and mainly show the same old crap, only at different times. Other than that, the only other station I care to get is 58-1 (CBS) - mainly just for another option, in case for some reason I'm not receiving WIFR-DT well (since I don't get WBBM-DT). I get the South Bend CBS on occasion (WSBT-HD?), but that's just purely through tropo.
I saw the two digital tunered units at BB the other night. They're LG's. One is a VCR/DVD recorder and the other is just a DVD one. No hard drives though. I don't think there will be any of those coming out in the near future. At least not from what I've been reading in the DVD Recorder forum.
Maybe when they have a sizable HDD, and an upgraded TVGOS that works with digital (or something similar), I'll think about getting one. Oh - and one that's guide recording is fully compatible with satellite. The LG's had listed on the box and unit sticker that the IR blaster will control satellite tuners, but I'm already setting timers manually with my SD Sony DVR and E* tuner, so it wouldn't be an upgrade for me (my Sony will control it through it's IR blaster, but I don't use it).
