AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › Cable TV to Projector (no PC)
post #1 of 4
Hi all
I want to connect my cable tv to my projector and bypass the PC. I am looking for a way to run the cable from the wall to some sort of converter that will output to s-video or a yellow rca. I'm not worried about the sound, I have that covered. Is there a simple conversion box or cable that can do this? I have looked all over.
PS. Currently I have a TV tuner in a media pc that is then connected to the projector via VGA. I would rather skip the PC due to resolution distortion.
post #2 of 4
Use a VCR as the tuner/modulator.
post #3 of 4
You could also use a cable box. Some projectors, (like InFocus) include VESA-to-Component Video adapters. You can use one of those adapters.
post #4 of 4
A cable ready VCR should tune in the non-scrambled non-digital channels.
For best results, use the cable box that goes with the cable system.
Video hints:
http://members.aol.com/ajaynejr/video.htm
  Back to Forum: Cable, Digital Cable - Non-HDTV
