AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › HD compatibility with cable company?
post #1 of 9
my 5070HD comes with Dual NTSC and ATSC Tuners. but i heard unless my cable company's HD signal is compatible with the specific HD tuner i have in my tv i still need to buy some external HD decoder box. is this true? i'm using Charter cable company btw.
post #2 of 9
i think the better way to ask this question is: i have a cable box from charter communication, in order to receive all the HD channels do i need an extra cable box or my built-in HD tuner in my plasma will pick up the HD channels automatically. thanks.
post #3 of 9
just called my cable company, they told me all i gotta do is replacing my old cable box with the HD version one and i won't need a cable card.
post #4 of 9
Just to flesh out your understanding a bit:
The cable box is a tuner. With a cable box you don't use the tuner built into the tv. The tuner built into the tv is used only for over-the-air HD signals from an antenna or with a cable card (if your tv has a cable card slot).
-Eric
post #5 of 9
Cable companies are now employing QAM (Quadrature Amplitude Modulation) on the digital channels. If your tuner is QAM capable then you can receive all the non-encrypted digital channels (HD & SD) . You will have to do some searching to find them. Cable Cards will give you access to the encrypted channels as well, but not pay-per-view. The cable company, however has to provide, program and rent you the card. This is not something you go out and buy. A Cable Box will give you access to everything your cable company has to offer.
post #6 of 9
-Eric
thanks, i honestly did not know that. so by switching to the HD version of my exsiting cable box and if i just wanna see the channels i was getting and the HD version of them if available then i don't have to rent the cable card correct?
post #7 of 9
so just to clarify this, if i upgrade to the HD cable box then i'll be getting the same channels i'm getting right now plus their HD versions if available and i don't need a cable card, right?
post #8 of 9
Yes that is correct.
post #9 of 9
Many channels are encrypted, so you won't get all the same channels you get with the cable box / DVR.
You will get all the channels that you could get before with the cable connected directly to your TV, plus DTV/HDTV versions of your locals.
