Hi there,
Need some expert advice here.
I am researching an RF distribution setup for my work.
The story is as follows: I will be setting some equipment up at a tradeshow. We will be receiving one coax cable drop to our booth of unknown signal quality, however I need to feed 3 ATSC tuners from it.
So basically, it seems that an amplified RF splitter is called for. Internet research seems to show that the ChannelVision CVT-2-8PIA-II is the best available amplified RF splitter.
HOWEVER...
From reading around it seems that ATSC means that I should get a splitter that goes from 5-2100mhz, and the spec on the splitter only talks about 54-1000mhz. It does say that it is "DTV/HDTV approved" -- but god only knows what that means.
What are your thoughts on the matter? I can get a passive splitter, but do not know what the signal strength will be like when I arrive, and I cannot leave this to chance. Will the channelvision splitter do what I need? Any other advice?
As far as the ATSC receivers go, I've been looking at getting three of the el-cheapo RJTech RJ-1000ATSC receivers. Thoughts on that welcome too!
I am researching an RF distribution setup for my work.The story is as follows: I will be setting some equipment up at a tradeshow. We will be receiving one coax cable drop to our booth of unknown signal quality, however I need to feed 3 ATSC tuners from it.
HOWEVER...
