AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung LN-S4095D picture mode problems
post #1 of 2
New to this site and thanks for the response ahead of time. I've noticed in the last little while when i have my TV's picture mode set to "MOVIE", after about an hour or so, it reverts to Dynamic. Anyone have this problem before? What did you do? I got mine from Best Buy.
post #2 of 2
You may be in Shop Mode. With the set off, hold down the power button on the set, not the remote, for 5 seconds. A menu should come up that allows you to choose either Shop or Dynamic mode. You want Dynamic.
Shop mode is designed for sets on display in the store. It resets all of the settings back to a default after a set period of time, so that if a customer screws it all up, it'll go back to normal by itself.
