Need some suggestions/comments on this....I'm wanting to know if you can "paint" this material with one of the many methods from this forum to achieve better gain. (if it is even has to be done, 1.2 gain already)
Will this ruin the AT, and or the material itself. The reason I ask is I want about a 9-10'(W) 2.35 screen. I'm using a IN76 and it can be mounted anywhere up to the back of the rm (25') only thing is my ceilings are vaulted (8'-12') so i dunno if ceiling mount will work, if not a "pole" will be used. (light controlled dedicated theater)
