AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Hour Counter for 5070 HELP!!!
post #1 of 3
Im sure there are posts on how to check hours for the pio 5070.
I checked for about 20 minutes and saw related post's but no actual answer to my question. Can someone please quickly reply and i dont need to hear "do a better search" or some smart ass answer!!!! Thanks everyone for helping this forum is AWESOME!!!!!!!
post #2 of 3
Post 2800 of this thread: http://www.avsforum.com/avs-vb/showt...t=service+menu
Just an FYI...if you have future 5070HD questions, and want to do a search for them, go to the 5070 owners thread or the 7th generation pioneer thread, and then do your search in there. You will have much better results.
Good luck!
post #3 of 3
OHHH Ok cool thanks for the info!!
