I want to upgrade my computer's sound card to a Creative X-Fi Platinum but I don't want to use the control bay thing for the audio. It doesn't fit my case because of the swinging cover door (it won't close because of the knobs) and I definitely don't want to connect my receiver through the front optical port which looks really dumb.
So I want to use the analog connections on the sound card to hook it up to my HTIB receiver (Onkyo HT S790). The receiver is about 9' away from the computer so I'm looking to get 12' cables.
Does the quality of RCA cables matter? Looking at monoprice, their premium cables are about 2.5x as much as their regular cables.
Also, if the premium cables are better, then what kind of a splitter should I use? I need sometime to split the 3.5mm into two RCA Female but monoprice doesn't have anything like that. They only have 2 plug RCA Male/Male cables.
