Hi All,
I have an HD A2 with my Denon 2807 using HDMI cables to hook them up. I use the Toshiba for CD's as I do not have a dedicated CD player.
When I am listening to CD's the receiver clicks then the sound shuts off for about 2 sec and then back on. I assume something is triggering the protect circuit but it only happens while playing CD's and never on movies, or while watching TV thru the Comcast HD tuner.
This leads me to believe the Denon is fine and a problem may lay with the Toshiba. I have re- attached all of the banana plus for all my speakers connections and am confident that there are no loose speaker wires.
Has anyone heard this happening with others
DN
DN
