Hi guys,
I'm breaking my head over this one. I have a laptop with a Soundblaster Audigy 2 ZS PCMCIA sound card. I'm quite sure that all I did was install AC3Filter and dtswavsource.ax. With those two in place (again, I'm pretty sure) I was able to play all of my DTS encoded WAV and FLAC files with no problem at all. The card was outputting via S/PDIF over a Toslink (optical) connection to my receiver and my receiver was doing the decoding... with no problem at all.
Now I built a true HTPC using a X-Meridian sound card. Just for informational purposes only, I originally had a Soundblaster Audigy 2 ZS PCI card in there and was experiencing similar problems. The only difference between the HTPC setup and the laptop setup was that the HTPC setup is going out over coax and analog vs the optical from the laptop.
I can play all stereo content with no problem (sounds fantastic with the X-Meridian!). I can play them in both analog and digital but I ideally want to do everything analog. The DACs of the X-Meridian appear to be substantially superior to those found in my Pioneer Elite VSX-74TXvi. I am also able to play Dolby Digital and DTS DVDs using Power DVD all in full surround sound.
The problem comes when I attempt to play DTS encoded WAV or FLAC files. So far, the best I've gotten was with VLC Player playing the wav files in stereo. Anything else that I do gives me white noise. I've tried both analog and digital setups with the same result. I've tried AC3 Filter, NVIDIA PureVideo decoder, FFDShow, KM Player, Power DVD, etc... all with the same results. Whether I try to pass the audio over S/PDIF or have the XM do the decoding it makes no difference.
If anyone here can shed some light on this I'd be eternally grateful. If any of you are from the Montreal area I would pay you handsomely to come by my place and troubleshoot this for me. If I try to think any harder I'm going to give myself an aneurism!
Please, I'm begging you guys, I really need help on this BAD!
