AVS › AVS Forum › Display Devices › Display Calibration › When should I have my HDTV calibrated??
post #1 of 4
I purchased a Sony SXRD 1080p 55" yesterday..... Magnolia will be here today for the premium install.... When I purchased the tv, they told me that the calibration was included.... I was just on the Magnolia website and it mentioned that a tv should be in use for 100 hours or about 3 weeks before calibration should be done.... At his point, I have only 1 hour lol..
Thoughts?
post #2 of 4
I would get familiar with the television for a while anyway. Play with user controls, try out different settings, get a feel for what you like and dislike so you can tell the calibrator when he gets there and he has something to work with.
Kenal0
post #3 of 4
Kenal0
Thanks....
post #4 of 4
Greetings
Minimum of 50 hours on the bulb to burn some stuff off. The bulb changes color a bit during this period.
After this ... further break in period is to determine if the tV is a DUD ...
Sometimes you'd like to wait a month ... and then do it.
Regards
