I know this has been hashed out before, but the last big thread I found was from 2004, so I thought I would do this again.
I currently have an Insteon system with about 80 devices and I am just about done with it. Too many switch failures to keep the wife and daughter happy. I was waiting for Leviton Vizia RF stuff to come out, but now that it is out and I have seen some of the documentation, it has too many limitations to do what I want it to do.
So that leaves me with 2 real options. Lutron RadioRA or Homeworks RF. I know about Starlite, but the wife likes the look of the Lutron stuff better, so that is the direction I am going to go. She is already unhappy that I am going to rip out all the switches I spent a few months installing, but she is more upset when they don't work, so she gets her way with choosing the new ones.
I was ready to go with RadioRA and as I was doing some research, the Homeworks RF kept coming up. So I did some research on it and from what I can learn, it is close to a wash pricewise in a larger install.
Here is what I have: About 70 loads counting everything from closets to the attic lights. (Insteon actually shines here with their timer relay which can shut off the lights after 15 minutes) and another 23 or so multiway switches many of which will be replaced with controllers.
So I am at the upper end of RadioRA limits of 64 devices. I can do without many of the loads being automated, but low to mid 50's is probably the minimum.
I like that I can buy RadioRa locally or online with ease. The closest Homeworks dealer is 140 miles away. So I would need a source.
This will be a 100% DIY project from installation to programming and I know Lutron frowns on that for Homworks but that is how it will be. Also, the project will be done in stages with a larger initial purchase to get critical areas done and then basically a room or two a month until its done.
But here are a couple of questions:
1) How bad is RadioRA with "staging"? Most of daily button activity will be via controllers controlling 3-5 loads. I have read that RadioRA sends out the commands one at a time and lights come on in sequence. How long does this take? For example, in the MBR, there will be a controller "room" button that turns on the MBR lights and 3 loads of bathroom lights. Will I be able to watch these lights come on in stages or is it quick enough that you notice it, but you are not "waiting" for it.
2) Status light question. Let's say I have 6 controller buttons throughout the house that control 2 loads of outdoor spots. If I turn on the spots via "Controller A", its status light will come on and stay on as long as the spots are on. Will the status lights of Controller's B-F also come on to indicate status?
3) How qucikly do the lights actually respond? For all Insteon's faults, for the most part the repsonse is instantaneous. Aside from the staging issue above, how quickly would a load respond to a controller? I have also read that when using whole house scenes with the Chronos, that there is a 2 second or so delay for the scene to fire. Since Homeworks uses basically the same process 100% of the time, it there a similar delay?
4) Programming. I know what a pain it can be running around the house programming buttons as that was how I programmed much of my Insteon system as it was installed before Powerhome/Houselinc were available. Will the centralized programming of Homeworks be that much better as I expect given the quality of Lutron, I won't be replacing switches on a monthly basis. How hard is it to program Homeworks with the programming software? Keep in mind in the past year I have learned both Powerhome and Houselinc and have dabbled with Homeseer, so I have some experience is how these programs work. Or am I in for trial by fire?
5) Cost. I have read that the cost difference between RadioRA vs. Homeworks converges as the install gets larger. Given that I will require a Chronos with a RadioRA install, I am assuming I will be close in price with either option. Given that I will need a Chronos and it has to be the "main" repeater, it will be part of any RadioRA install from day 1. I have found RadioRA dealers that sell at basically 66% of retail. Can expect about the same ratio for Homeworks RF?
6) Dimming status. I know there is more capability with Homeworks to report status, change levels on the fly etc. But it really doesn't matter much to me as I am more of a "set it and forget it" type person.
7) Keypad controllers. Are the Large-button See-thru controllers available for RadioRA also available in Homeworks RF?
8) Availability and documentation. As mentioned, my closest Homeworks dealer is 140 miles and there is no guarantee the dealer would sell to me anyway, does anyone know a dealer will to sell to a homeowner? And include programming software? Also, RadioRA documentation is readily available, but I have had trouble finding detailed information about Homeworks RF. Most of the homeworks stuff I have found deals more with the wired versions vs. the wireless.
Yeah, I know its a lot and any help would be greatly appreciated.
