AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › Which CD player to buy?
Which CD player to buy? - Page 13
post #361 of 366
Originally Posted by Chu Gai View Post
If this site permitted the disclosure of IP addresses while posting you'd find that indeed Charles and PULLIAM are not the same person.
One account with one ISP usually results in a server-side IP address being assigned each logon. The assigned IP address is usually different each time a user logs on as the server will assign one from a range of IP addresses. Unless of course a user has a fixed IP from their ISP, which is not common I thought?
post #362 of 366
You're far more likely to find such duplicitous and cowardly behavior with a person masquerading as another by looking at the head honcho over at Tara Labs
post #363 of 366
No, "?????????". He or someone representing the company did it. He was nailed on another website that tracks IP's and makes them public.
post #364 of 366
You could always use a third party proxy server anonymizer (like anonymouse) and register under any user name you like, as long as you have a different e-mail address for every registered account. This would assure that your IP would not be your own on any website you post on, assuming the website allows you to use a proxy. Even if the website doesn't allow anonymous proxy usage, it would only be able to do so by tagging certain IP addresses as forbidden (becauase they are usually proxy sites), this can be bypassed also if you know what you are doing...
post #365 of 366
Thank you. In the extremely unlikely event that I should ever decide I want more than one forum ID, I now know how to do it.
post #366 of 366
You only know the easy one (which many sites block - I'm not sure whether this site blocks it...). The more creative ways of spoofing I'll refrain from posting here.
