AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Mixing 8 and 6 Ohm Speakers with a Yamaha RX-V659 / HTR-5960
post #1 of 2
I'm a Yamaha RX-V659 owner for all of 24 hours. For the moment, I've got it hooked up "old school", to just my two "actual old school" Genesis 33 speakers. I see Yamaha makes a big deal about specifying 6 or 8 ohm speakers, and the 33's are indeed 6 ohm, so that's what I've selected. I suspect most all of my others speakers (some still to be acquired) are 8 ohm. There's no mention in the manual about mixing 6 and 8 ohm speakers - is that because it's a no-no?
Is there a means to convert 6 ohm speakers to 8?
Appreciate any input...
post #2 of 2
Just leave it set to 8 ohms and enjoy your system and don't worry about it you will be fine.
