AVS › AVS Forum › Blu-ray & HD DVD › HDTV Software Media Discussion › Format Battle General Discussion Thread II: Discuss it here!
Format Battle General Discussion Thread II: Discuss it here! - Page 56
post #1651 of 2493
Originally Posted by AnthonyP View Post
agree, we are already not getting 100%, that is why we talk of 16/48 or 24/48 or 24/192 (the highest grade master that these media can support). I just want ot make sure my senbses and my attention is the issue and not because some pencil pusher does not want quality
the issue is this is what Dolby has to say
if 1.5mbps was enough for all encoding (or what ever value some pencil pusher at the studio decided to use) why the hell is DTHD need up to 3mbps for 16/48 and 5 mbps 24/48 for 5.1? 3.5mbps 2-4x as much BW needed is a lot of information that is missing. Not garbage but useful information that should not be missing.
http://www.dolby.com/assets/pdf/tech...0925_Final.pdf
You seemed to have snipped my questions to you in this post, as well as having avoided answering them.
post #1652 of 2493
Well besides the fact that 720p clip looked rather overcompressed to me there is one fatal flaw with this idea
but richard if someone is looking at it on their 5" TV they can't tell the difference
post #1653 of 2493
Steve do they need an answer?
well if you want one. Luckily unlike lossless audio you can search the internet and get it because in 1st grade science teachers teach this stuff.
suffice it to say there are three primary colours
red green and blue these are called the additive primary colours. putting them together in different proportions can give you any colour. Many colours (like Magenta) don't even have a wavelength and most objects get their colours from absorbing several wavelengths.
Now that you learnt what you should have back in grade 1 we can continue the discussion.
post #1654 of 2493
http://www.asahi-net.or.jp/~ch2m-nitu/koorogie.htm
post #1655 of 2493
Anthony, do you still maintain that there's the likely possability that lossless decoders will not in actuality return the identical bits under some circumstances?
Steave: that is not what I said. I said I can understand why someone would prefer PCM because there is always the possibility that some players might have some issues with some decoding.
Horse hockey. That's exactly what you said:
even though I am not asking for PCM (Lossless is OK) what ytou are saying is not right. You are forgetting that with any encode you have two week points that you don't with PCM.
1) an encoder
2) a decoder
just because all the information is there to get back a lossless rendition does not mean it will happen. For example (reason) the processor might not be powerful enough and it messes up on decoding. Have you ever had a PC where while watching something/playing a game it slows down or stops?
Just look at the guys that did a review between the BD and HD DVD and heard some differences between the two.
The reason I don't care as much (PCM or other lossless) is that if the data can be recompiled it is up to the buyer to get a machine that does it right.
And then again:
Someone stated that a lossless encode necessarily meant a lossless decode. And that is not true. It might always happen in all players, but it is not necessarily so. I clearly stated in each of the posts that lossless encodes are good enough for me, but that I can understand why someone could want PCM and I decided to give an example. An other reason (mentioned before is the guy might not have a player that can decode every lossless).
As to your test, that is a stupid comment. I won't go with HTPCs or anything else. But none of these players have separate audio and decoding chips. So there is literally no way to test all systems.
Back to your reply above...
Unlike you I live in the real world. DL DVD was in the disk specs and especially early on there were many players that had issues with them. HD DVD fan boys whine about BD profiles and how they will cause issues, but even though there is only one HD DVD spec and one HD DVD CE manufacturer there is at least one HD DVD movies that won't play on the 1G Toshiba players (Plazman and Grubert were discussing it in an other thread). Sh!t happens. DTHD is in the HD DVD specs but by the simple fact that someone can build an HTPC with an HD DVD drives make this whole conversation moot. None of them (especially because you did not ask) have talked about why every player at every time must decode flawlessly or what will be the ramification if it does not (except that it would be audible). You asked if machines/designs are tested, well d'uh. But everything has tolerances and everything does not go right 100%.
I am sure Keiths chips are of the highest quality, does that mean every player will get the same? how about those cheap Chinese ones?
PS you had asked me all those questions before and I had agreed with you, so don't know hwt it is suppose to mean.
So let me get this straight... you are concerned that somehow players are gonna flub up lossless decoding. What about MPEG2? And AVC? And VC-1? And scaling? And compositing? And their TCP/IP stack? etc, etc... Yet they'll get PCM right. They won't round it incorrectly for DAC's that don't take 24 bits in. They won't cross stereo pairs. They won't resample.
And you are questioning whether I live in the real world?
post #1656 of 2493
Before I respond to this, let me be absolutely clear. Are you claiming that a 3-color primary model is how "real life" works, and not simply a perceptual model we use in display technology?
Is that your "1st grade" basic teaching claim?
post #1657 of 2493
I'm not saying studios should not use it ... I'm saying that PQ is most important,
agree with you on that
and I'm saying that Studios, (1) knowing what the mass market consumer will likely be using to playback these titles and
but that is the thing losless audio adds more in this respect then anything else. There was a thread in the BD forum where someone set-up his PS3 incorrectly and was getting SD out of it. He said BD looks just slightly better then DVD but sounds much better. Whe he realized and switched to HD he responded "now I understand"
Lossless audio (unless you gave a 360 add-on) adds more then you think. Even if some connects a player to an old SD set using RCA connectors (analog audio and composite) he can hear the benefits of lossless, he can't watch HD (his set is SD and only accepts SD over component) so it is SD just not as over compressed as DVD, he can't hear the surround (and 5.1 is nothing new) but those analog cables bring out the lossless (from PCM ordecoded DTHD) to his speakers
(2) knowing that the perceptible difference of lossy vs lossless is minimal (if at all), will probably not want to use it.
that is the issue the difference is much bigger then you think. It is similar to someone saying the difference between SD and HD is minimal (after all it won't change the acting and most people don't count freckles to see if one is missing due to resolution)
They would much rather spend their time adding some deleted scenes, that everyone can see versus some audio that the majority will not even know is there.
but what they want is what sells. What sells should be what we want. This is what is most annoying with this discussion we are telling studios we would rather have garbage on the disk then quality. why? because some overzealous fanboys decided that that cheerleading is more important.
post #1658 of 2493
Originally Posted by eecubed View Post
192kbps for 2 channels is roughly equivalent to 640kbps for 5.1. Have you petitioned all the studios using 1.5Mbps audio to stop using so much BW because you won't be able to hear the difference?
Let me first answer your question.......No. My speakers extend to 29Khz. I'm not calling the manufacturer to ask them to change their design. At the same time I don't believe I'm able to hear anywhere close to a 29Khz frequency.
Now I'll ask my question from the post you qouted.
I've done blind testing, and I know I loose the ability to detect the difference between lossy and lossless at about 192kb/sec. Have you ever tried this out to find the limits of what you can detect?
post #1659 of 2493
no it is not
there is a world of difference between that and
Anthony, do you still maintain that there's the likely possability that some lossless decoders will not in actuality return the identical bits under some circumstances?
the first one is no the second one is yes. The first one assumes I think it for all devices. I alreaduy said that I assume it to be an exception. But for all I know that guy wanted to watch his movies on an old PC that can't process DTHD correctly and he would get the glitches.
post #1660 of 2493
not at all. what I am saying (might this might be high school science) is that the eye has a retina, the retina has rods and cones. Rods are not important in this discussion since they are not colour sensitive. Cones are divided into three categories red, green and blue (wow what a coincidence they match the primary colours) depending on the wavelengths they react to, these reactions are then sent to the brain and we see colour. if the eye gets yellow wavelength the green and red react and send a signal, if the eye gets red and green wavelength the red and green cones react and send a signal to the brain. In both cases it is the exact same signal that reaches the brain and we see the exact same thing.
post #1661 of 2493
For efficiency sake, I'd refer you to the feedbacks that you received from the AVS members when you posted your statement the first time for the details. Your rationale that any codec, which can deliver a 5/5 PQ result, is somehow inadequate PQ wise is incorrect.
Out of curiosity, does anyone have the PQ numbers for the Paramount VC1 encodes in comparision to their equivalent MPEG2 encodes? I'd like to see the results since Nov 2006 and since inception.
Maybe I missed it, but yours was the only significant feedback I saw.
Let me see if I follow your point. Mpeg2 has delivered some titles that score a 5/5, therefore Mpeg2 is just as good as AVC and VC1. Is this correct? If so, are the studios wasting their time with AVC and VC1? Is it a statistical anomaly that Mpeg2 titles average lower PQ scores on both BD-25 and BD-50 (vs. AVC and VC1)?
Maybe my theory is wrong. Maybe there's some other logical explanation, and all this effort to create new codecs has been a big waste of time that does nothing but add more licensing costs to all of these players.
I find it ironic that you're in favor of lossless audio, but when it comes to video you're very supportive of a 12 year old codec vs. two newer more advanced codecs.
post #1662 of 2493
Alert the media I'm going to support Anthony. Yes, RGB additive color is pretty-much the way light and color work in nature. Subtractive color systems (like CMYK) have much narrower spectrum, and approximations/simulations of RGB.
That's why you get colors on your (RGB) monitor that cannot be reproduced in printed (CMYK) form.
It's very counter-intuitive, in that for example an orange Jack O Lantern, is actually every color that compliments orange, because that is the color(s) it cannot absorb, and that's how RGB works. If you intersect a Red, Blue, and Green beams of light, you get pure "white light"
post #1663 of 2493
Originally Posted by nataraj View Post
I don't think bandwidth will expand as fast as fall in CF prices - so even if the memory in players is very high - we won't be able to download fast enough for us to have a seemless optical + internet download experience.
That's a very good point ... the new SDHC cards are > 9mbps I believe ... what do you think it would take? 2x that? 3x?
I did say wishful thinking.
post #1664 of 2493
Actually I was talking about internet bandwidth.
Let us say you have a huge CF memory in the player. What would you use it for - probably the extras - which will then seemlessly be played along with the movie on the disc. But the problem is they have to be downloaded everytime you load a new disc. And if you have even 4GB of memory that would take a long time to fill up through Internet - and nobody will have the patience to wait ...
post #1665 of 2493
You mean we have a sun that radiates only red, green and blue in the visible spectrum? That was the point.
post #1666 of 2493
no it is not
Well, there's a good reason to suggest we should have PCM on discs. I'm sure the video looks stellar at 8fps too.
post #1667 of 2493
And what you have described is how humans PERCIEVE color.
Now, do you recognize that is NOT how bodies radiate color?
We may be getting somewhere.
post #1668 of 2493
Perhaps we are on different pages here, Timothy. I was not challenging the additive versus subtractive nature of color system, but rather asking Anthony if he thought that a "primary color system" was actually how light is physically radiated from a body, as opposed to it being the perceptual model used by display devices to exploit our visual perception.
IOW: Did he recognize that orange is physically radiating off the fruit as a 590nm wavelength in real life, not as a combination of 570nm (Yellow) and 650nm (Red) wavelengths that our eyes perceive as orange.
post #1669 of 2493
Yes, that's what I was getting at.
Ultimately I'm challenging the notion that for self-evident truths (i.e.- a perceptual model != physical mechanism) that studies are not done to determine the degree to which the perception is accurate to the original.
I think maybe Timothy thought I was challenging additive vs. subtractive, which I was not. Both are perceptual models for different applications.
post #1670 of 2493
Woohoo! We agree on something!
And how many other 'average consumers' are going to hook up there gear incorrectly and not have the benefit of AVS to help them fix it?
Sooo ... we want lossless because it is closest to the master ... but even a lossless encode piped over analog connections is going to sound better than a lossy encode piped over the same analog RCA's? I'm gonna have to try this myself, because I don't see how I could tell a difference.
Perhaps ... but this is where you and I largely disagree. Your opinion, which you state as fact, is that the difference is large. My opinion, which I state as opinion, is that I don't notice a difference and I don't think the average consumer will either.
Again, it's up to the studios, like you said. They feed us extra content that many BD-advocates say they could care less about (I kinda like having them, though I must confess I rarely watch anything other than deleted scenes and bloopers, if that).
And, please, can we stop with the 'overzealous fanboy' stuff? You can make your point without calling those people who disagree with you stupid, dumb, ignorant, fanboy, etc.
post #1671 of 2493
I was thinking more as a replacement for HDD's and things like that ... wrt Consoles, etc.
But, couldn't a second disc be used to load up the CF storage for separate audio tracks or perhaps a separate PiP encode or something? Then the secondary decoder would have full bandwidth available for that content and HD-DVD could theorhetically provide every language on the planet without sacrificing bw?
post #1672 of 2493
If the guy has an old PC, then he probably doesn't have the equipment to hear loseless.
And this should be taken differently since I thought that the players made have to pass specs in order to have the logo's and be licensed for the technology. People with PC's don't have this to worry about.
post #1673 of 2493
Indeed they do. You are spot on.
And although AnthonyP would like us to forget that in this post he wasn't talking about PC's at all, but the hardware within dedicated decks, much of the converstation was indeed about exactly the sort of hardware testing/compliance to which you refer.
post #1674 of 2493
That is possible.
post #1675 of 2493
Does anyone know what this really says?
Something about Wal-Mart and Chinese Players ...
http://www.avsforum.com/avs-vb/showt...&#post10344181
post #1676 of 2493
It seems WalMart has ordered 2M HD DVD drives for the holiday season. Possibly they will get someone else to build the player using the drives and sell the players at an attractive price during the holiday season.
This can be a decisive event is the format war.
post #1677 of 2493
Well, we know the Chinese have officially adopted HD-DVD as their high def format for domestic use. Of course their version uses their own home grown AVS codec instead of the standard three.
I believe the article relates to their beginning production of HD-DVD drive mechanisms. That's good news in that the increased production volumes will help drive further cost reductions. I'm not sure how Walmart factors in unless they plan to be the retail distribution arm for a lot of these players.
Did anyone else catch the new SoC announcement Intel made at the Beijing IDF?
Intel integrated media SoC boosts A/V processing
http://www.edn.com/article/CA6434434.html
The Intel CE 2110 media processor is a complete system-on-a-chip (SoC) architecture that Intel said combines a 1GHz processing core with powerful A/V processing and graphics, and I/O components, onto a single chip. The SoC includes a 1 GHz Intel XScale CPU, MPEG-2 and H.264 hardware video decoders, DDR2 memory interface, 2D/3D graphics accelerators, and is supported by a modular software development environment. Intel also said that its platform architecture also allows CE developers and manufacturers to deliver pure IP or hybrid set top boxes designed to receive content from IP and digital broadcast pipes.
They don't mention VC1, but if it can handle that as well, it seems like it might be handy for building high def players. Perhaps there's a different flavor of this chip coming soon.
post #1678 of 2493
I noticed recently that the last two encodings from Universal, The Jerk and The Game, were rated pretty low in video quality at High-Def Digest. Not that it matters much but I am a bit surprised at the hypocrisy that a few posters have when it comes to the two HD formats. A Blu-ray disc with a 3 star rating in picture quality causes them to make mocking posts against Blu-ray in this thread, but I never hear a peep from those same posters when discs like these are released on HD DVD. Maybe it is just me but I think if someone is going to mock an entire video format simply because of an encoding that was made for it they should at least be consistent about it.
post #1679 of 2493
I bet you were on the edge of investing in an HD DVD player until this setback, huh Richard?
post #1680 of 2493
Thank you Richard. I've updated my spreadsheet. The current percentage of stinkers (3/5 or lower PQ) stands at
HD-DVD = 10.65%
BD = 13.04%
It is certainly dissapointing as this is the first time I've seen HD-DVD go above 10%.
  Back to Forum: HDTV Software Media Discussion
This thread is locked
