AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › Motorola DCT inputs
Motorola DCT inputs
post #1 of 3
OK, I am new on this forum, but is seems to be the place to get the corrent answers.
I just picked up a DCT6416 from Time Warner(Los Angeles) and I am now maxed out on my inputs on my TV until I get a new LCD.
Anyway, I am running the DCT to my component in on my sharp tv. Now I have a slightly older DVD player that I would lik eto hook up to the DCT input, but I dont know how to access it to make it play.
I called Time Warner and they said that is nothing they can do and to call Motorola. So I call them and they say it has to do with the programming with the cable network. So now I have called both and no one has an answer.
I picked this box because it had the 2 inputs on it so I could hook up my extra components.
Any help would be great. I tried searching, but nothing concerning this came up.
Jason
post #2 of 3
The inputs are not functional. They are not supported by the software on the box.
Time Warner has no plans to support those inputs.
post #3 of 3
Thanks, I guess I will just take this box back and get the smaller sized one with the bigger harddrive.
Jason
  Back to Forum: Cable, Digital Cable - Non-HDTV
