Originally Posted by GoCaboNow
I can mount the pj any where from 15' to
24'. So, with that in mind...
1)How would the Prismasonic 5000 or Panamorph 480 compare for my setup? 2)What would be the sweet spot for these two lenses for this screen?
Any help is greatly appreciated and, Aussie, I apologise again for the name I called you.
I checked the specs of high end anamorphic lenses, and found out that the amount of available technical information is embarrassingly low.
The only data I could find about the focusability/sharpness and the sweet spot was Panamorph UH480. All other lenses including ISCO III did not give any data about the focusability throw range. If I have missed any data please fill it up. Above technical discussion indicates that even top end lenses (ISCO III and Schneider) with focus adjustment have a throw range for razor sharp focus. However, I couldn't find this data.
Panamorph focus ranges:
14.5' - 17.5' UH480 standard
17.5' - 20.5' UH480B
20.5' - 24.0' UH480C
24.0' - 29.0' UH480D
29.0' - 40.0' UH480E
I expect these different UH480 models have cylindrical lenses with different focal points to achieve sharp focus for the given ranges.
I couldn't find any focusability data for Prismasonic HD5000. It has single spherical lens to obtain sharp focus in contrast to multiple cylindrical lenses in UH480 to obtain multiple focus ranges.
If anyone could find focusability data on other high end lenses please post. Thanks.
. And, as far as I know, everything AB reports about their presumed design and performance is hypothesis, and almost always negative. Last I checked they sure aren't releasing how they design their lenses. It took Schneider almost 2 years to bring the larger prototype to market, it's not as easy as AB makes it sound, apparently. So factor the input accordingly. My string pulled. Now back to work...
