Hi everyone. This is my first time posting, but I've been reading for a while now. I'm sure you get asked this a million times, but I can't seem to find anything specific to my dimensions.
Anyway, I am about to start putting together my home theater and I'm having a size problem. In my basement I have two rooms. The first room is where I originally planned to have the equipment set up, but the problem is that it's plenty big, but oddly shaped. It's rectangular, but it's got some odd walls that come out, so I'd like to see if the other room is too small or if it's usable. The dimensions for this room are 16' x 10'. If I used this room, I could use the other room for a pool table room.
If I do this, the TV, which would be a 50 - 60" plasma, would be hung on the wall. I would put a couch on the other wall which would give about 9' of viewing. The ceilings are 8'.
I don't know if it matters, but I will be using a Denon 3805 with Klipsch floor standing front speakers and in wall for the rears...and possibly for the sides as well.
Anyway, my question is, is this just way too small for something like this, or is it just big enough to be "intimate"? I appreciate all your responses.
