AVS › AVS Forum › HDTV › HDTV Technical › Antenna Set Up Help
Antenna Set Up Help
post #1 of 9
Greetings all.. I just bought a Channel Master Gemini MNT 1000 antenna. It is a super fringe antenna. 100+ miles VHF.. 100+ miles UHF..
Instructions were not only written bad but the print on the instructions were so light I could not read them. I installed the antenna the best I could.
My VHF seems to receive OK.. I am having problems receiving UHF signals. Anything above channel 14 is almost nothing..
I am not sure what the frequencies are for ATSC Channels. (maybe they are the same as NTSC).. I am able to get a digital signal on our local channel 12 which uses 16 for a digital channel. I am unable to receive digital channels 24, 29, and 40.
If I have problems receiving UHF channels. Is there a possibllity I may have installed or missed a step while assembling the antenna? could it be line loss? or bad coax cable?
The three HD channels I am unable to receive are located on a mountain about 50 miles away from me. I believe I am in a direct line of sight. My elevation is quite high too... I am about 4 miles away from the tower of a couple 100 KW Fm radio stations. Perhaps I am receiving interfearence from them..
Any ideas would be apprecaited.. Thanks..
post #2 of 9
using zipcode 54501 and lat long 45.639515, -89.412086 of Rhinelander, WI, there does not seem to be line of sight clearance to WSAW-DT. The two attached images show a hill (at the red cross lines) inbetween which would need a 380 foot tall antenna. Your location may vary.
post #3 of 9
I actually would live in Elcho. Zip code is 54428.
I can pick up WAOW-DT, and WHRM-DT.. But I can't only get a choppy signal.y.. WJFW-DT is fine. WSAW-DT I would LIKE to get.. That stations seems to be a major problem.
I didn't realize I was running a 100 feet of RG-59 until a few minutes ago. I thought I was using RG-6.. .. 5 DB line loss on channel 11.. 7 DB line loss on channel 50.. That isn't good.
What link are you using to figure line of site?
post #4 of 9
Zip code 54428 with lat long of 45.5 -89.1 shows about a 300 foot tall antenna for line of sight clearance to WSAW-DT. I'm using the Radio Mobile software with SRTM-2 data.
See attached images.
post #5 of 9
I probably have a couple of pine and maple trees in my yard that might be 300+ feet... Anyone have a way to get an antenna up there? LOL..
I suppose if I go that high.. I should have enough clearence for Green Bay stations... LOL
post #6 of 9
Here are a couple more pics with your precise location. WJFW-DT seems to need a 35 foot tall antenna for line of sight clearance. WSAW-DT, WHRM-DT, and WAOW-DT show about 75 feet.
post #7 of 9
thanks. that's a lot better than 200 to 300 feet..
post #8 of 9
ATSC use the same frequency as NSTC As you stated above WFW 12 analog but is digitaly transimit on 16 which remap to 12-1 on your tv.
I would change your 100ft RG-59 to RG-6 Quad it would make allot of difference by day and night atleast with the digital side.
Are you using antenna pre-amp ? If not I would add a Channel Master pre-amp 7777 with FM trap in. ANytime you have more than 50ft of coax it recommend that you add a antenna pre-amp.
I think if you makes those changes it would improve alot. But I would change the Coax first.
It would be nice if you could put your antenna on top of 1 of the 300 ft tree as long they don't sway in the wind .
Hopes this helps you
-Willie
post #9 of 9
Yes, replacing the RG-59 with quad shielded RG-6 is a good start.
However, have you looked up the broadcast power levels for the stations you are trying to get? I entered your zip and a antenna height of 500' to get a more complete list of digital stations (and to make up for where ever the center of your zip code is) and I got the following digital stations (ignore the color codes).
* yellow - uhf WHRM-DT 20.1 PBS WAUSAU WI 219° 44.0 24
* yellow - uhf WAOW-DT 9.1 ABC WAUSAU WI 219° 44.0 29
* yellow - uhf WYOW-DT 34.1 ABC EAGLE RIVER WI 351° 24.2 28
* yellow - uhf WFXS-DT 55 FOX WITTENBERG WI TBD 213° 30.1 55
* green - uhf WSAW-DT 7.1 CBS WAUSAU WI 219° 44.0 40
* lt green - uhf WTPX-DT 46.1 ION ANTIGO WI 213° 30.1 46
* violet - uhf WLEF-DT 36.1 PBS PARK FALLS WI 306° 64.7 47
(WFJW-DT does not show up, so this list is hardly complete).
A check for WSAW-DT CBS 7 (DT=40) at the FCC database (http://www.fcc.gov/fcc-bin/tvq?call=WSAW) shows a digital broadcast power of only 50 kW for UHF 40. That is not a strong power level for UHF, so that is probably why you are having a difficult time receiving the station. Many rural stations are not yet at full power on the digital signal, so checking their current power level at the FCC database or by contacting the station is a good idea.
Looking up WFXS-DT Fox at http://en.wikipedia.org/wiki/WFXS, it does not have a digital channel allotment, so it can't go digital until it shuts off the analog broadcast. hence the TBD in the antennaweb list. Unless there is another Fox station you can receive OTA, you won't get FOX in HD until WFXS does it's digital flash cut conversion, probably not until February, 2009.
PS. Looked up WFJW-DT NBC 12 (DT=16), it has a STA entry of 0.013 kW which is why antennaweb does not show it. However the FCC database also has a construction permit for going to 269 kW which is probably what the station is operating at.
  Back to Forum: HDTV Technical
