All of this has been discussed but I just need a quick and dirty recommendation / suggestion.
I'm upgrading from the Onkyo HTS780 7.1 HTIB and really I don't have any complaints. The reason for the upgrade is that I now need HDMI and more component inputs to accommodate all of my new toys and my new DLP 1080p TV.
I have an xbox 360 with hddvd (vga or component?), wii (component), HD DVR (component), xbox 1 (component), and a slew of gamecubes, snes, nes, n64's and other gaming systems that I want to hook up.
So my first question is should I go with 804 or 674 from Onkyo (or that Denon which is a bit out of the price range). Which does better HDMI upconversion? Why is the 674 more expensive on Amazon by $25 bucks? I don't give a whole heck of alot about THX certification.... Does Audyseey work on the 674?
Should I wait and buy a receiver that does HDMI 1.3???
After I nail down the receiver, I'd like to spend $500 on a 7.1 speaker package. I'm being told that the Velodyne front row set will set me back $300 then I can spend $200 on a sub. All and all -- I'm in it about $1,100.
Is there any better bang for the buck than this?
Do I wait for HDMI 1.3 even though my doesn't say it will support it?
