AVS › AVS Forum › Industry Area › Firewire 1394 Trade Association Q&A › How to record via 1394 from PC to D-VHS
post #1 of 6
Dear all:
I have a problem about how to record via 1394 from PC by D-VHS?
Could somebody tell me?
post #2 of 6
1) TSReader, play a stream and use 'Record program to DVHS' menu option
2) CapDVHS, use 'wrtdvhs' option
3) DVHSTool (anyone use that anymore?), has a way to write ts to DVHS.
post #3 of 6
I connect D-VHS and PC via 1394 and use wrtdvhs's option of CapDVHS
then start but TV shows that can not decode video or audio ......
what's problem with that?
Is there special requirements from my computer ?
post #4 of 6
Hopefully you are not sending your TV H264 transport stream files.
post #5 of 6
GraphEdit is another tool you can use. See this document for details:
Windows XP and D-VHS Howto
(This is a link to the copy at webarchive.org, since the original at webtc.com is down.)
post #6 of 6
If the show is 5C it will not be detected by a DVHS emulator only a DVHS machine ( I think
